what rpm are the stock cylinder heads rated to?
Old Nov 14, 2013 | 10:55 AM
crsracing19's Avatar
crsracing19
Default what rpm are the stock cylinder heads rated to?
Im curious to is the highest safe rpm capable of the stock cylinder heads on an 05 de non rev up good for before you get valve float or other problems. I was looking at raising the rpm to 8k when i do my rebuild but i was curious for all the mods necessary to do this for a twin tutbo build or if there's really any point to it, vs a standered forged internal. build
Old Nov 14, 2013 | 01:33 PM
terrasmak's Avatar
Contact JWT or Brian Crower
Old Nov 14, 2013 | 02:39 PM
jerryd87's Avatar
jerryd87
if your not getting cams its dumb since the power drops off, the cams arnt designed to rev to 8000 and still make power. if your upgrading the cams then the stock isnt strong enough and should be pretty obvious. of course all that has been covered before.
Old Nov 15, 2013 | 04:29 AM
Shin Beats's Avatar
Shin Beats
Old Nov 15, 2013 | 04:57 AM
tcode's Avatar
tcode
Sure it isn't ideal without upgraded cams, but you can raise boost where stock cams starts to fall and still keep decent torque and power up to the new higher red line.
