Tough gear shifts
Old Dec 29, 2013 | 10:09 AM
SharX59's Avatar
SharX59
Default Tough gear shifts
A little background about the car:
It's a 2007 nissan 350z, 6 speed with 44,000 miles. The car has a JWT clutch/flywheel, Z Speeed clutch slave cylinder, and wilawood master cylinder. The clutch fluid is ATE super blue and the tranny is running motul gear 300.
The issue:
In these past 2 weeks, the car has been extremely hard to shift into gear (especially from a complete stop). I need to really push the car into gear to drive. There is no grinding so I'm sure it is not the synchros. Odly enough, the more the car heats up, the slightly easier is to drive. Also on WOT shifting through gears the car acts normal. Anyone have an idea? I'm worried the car will soon become inoperable.
Old Dec 29, 2013 | 11:16 AM
POS VETT's Avatar
POS VETT
How close off the floor does the clutch engage/disengage ?
Old Dec 29, 2013 | 12:12 PM
SharX59's Avatar
SharX59
Almost as soon as you come off the floor.
Old Dec 29, 2013 | 04:44 PM
SharX59's Avatar
SharX59
Update:
Today when I tried to go somewhere for the first time, the clutch didn't sound like it was engaging and the car would not let me push it into gear at all. There was no give. After fiddling around with the shifter and clutch and 4-5 start-ups the car began to let me enter gears roughly.
Old Dec 29, 2013 | 05:45 PM
djamps's Avatar
djamps
You need to adjust the clutch. Engagement should be around half way for it to shift smoothly in all temp conditions.
Old Dec 29, 2013 | 07:12 PM
POS VETT's Avatar
POS VETT
That's the problem.
Old Dec 29, 2013 | 11:39 PM
cudaben's Avatar
cudaben
sounds like air in the clutch master/ slave setup or low/ no fluid. check for leaks if none- try bleeding it first. Its free and easy, if that does not fix it, well its a possibility that is now checked off the list. Don't throw money at something hoping it will fix the problem, start free / cheap and easy first. CHECK THE BASICS.
if it is getting worse it sounds like a small leak, or air in the system.
Old Dec 30, 2013 | 11:46 AM
SharX59's Avatar
SharX59
Well, I'm gonna take her to specialty z here in socal and have them go through the motions. I will update as soon as I find out the exact issue. Thank you to all of your replies!
Old Dec 30, 2013 | 01:30 PM
myfirstzcar's Avatar
myfirstzcar
Def not disengaging enough.
Old Jan 4, 2014 | 02:04 AM
SharX59's Avatar
SharX59
So I have an appointment for the 25th with SpecialtyZ to have the car checked out. Unfortunately today the car has pretty much crapped out on me and will not engage any gear.
Old Jan 4, 2014 | 07:29 AM
Spoolin'Fool's Avatar
Spoolin'Fool
mine is really hard going into the first 3 gears lately but once its hot its fine, which is wierd
Old Jan 4, 2014 | 12:23 PM
myfirstzcar
You may want to change the fluid spoolin', but it'll do that when it's cold anyway.
Old Jan 27, 2014 | 04:25 PM
SharX59's Avatar
SharX59
Good news! Well Sebastian from Specialty Z called me today and told me there is nothing wrong with anything. Weird right? Well, apparently the reason why i couldn't shift is because the Jim Wolf Technologies clutch has some sort of paint on the backside of the clutch. What happened was it melted off after the track and built up behind the clutch disk. This cause a build up of pressure behind it pushing the bolts holding the clutch in place out, in effect loosening half of them. I was pretty much driving without a clutch. so he is taking off all the remaining paint on the clutch and tightening the bolts back to spec and adding lock-tight.
SAFE TO SAY I AM EXTREMELY UNHAPPY WITH MY JWT CLUTCH. AND I DO NOT RECOMMEND.
Old Jan 27, 2014 | 04:38 PM
oldschool350z's Avatar
oldschool350z
Oh wow I'm glad I read this i was going to get jwt clutch.
Old Jan 27, 2014 | 04:42 PM
SharX59's Avatar
SharX59
Old Feb 8, 2014 | 06:36 AM
engleman's Avatar
engleman
Thank you for sharing indeed. I am also glad I caught this thread.
Old Feb 8, 2014 | 04:44 PM
SharX59's Avatar
SharX59
For sure bud! I'm happy to save people some headache! All the repairs cost me almost the same price as a whole new JWT flywheel/clutch combo -_-
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
