350z camshaft position sensor
Old Jan 21, 2014 | 06:56 AM
Black350z9972's Avatar
Black350z9972
Default 350z camshaft position sensor
I just finished a motor swap on my Z and it is not running right. It started up but once it did it made rapid back fire and a rough idle and set of service engine light. I read the code which said it was the crank sensor, so I replaced it with a brand new one. Started it again and it still had rapid backfire but seemed to help the rough idle until the next when it came right back (also did not turn off check engine light). So read the DTC codes again and this time it read "random misfire" & "intake camshaft position timing over- advanced" which may have been dirty sensor so I replaced them with the old engines sensors and cleaned the magnetic plate for better contact. Now it turns over but died 20 seconds later and repeats after every start up. I could use any help, thanks.
Old Jan 21, 2014 | 09:19 AM
chriswagner92's Avatar
chriswagner92
would the flywheel being put in the wrong way cause this you think?
Old Jan 21, 2014 | 10:05 AM
Black350z9972
It might we don't think we hooked up the flywheel the correct way. It went on flush so we figured it was good but come to find out there's a certain way to put it on. I was just hoping to find a different alternative
etkms
Jun 19, 2022 06:30 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
pslamp32
Feb 8, 2017 09:07 AM
350Z Project X
Oct 17, 2015 05:16 PM
RyansZ33
Sep 15, 2015 05:54 AM
