UR Pulley problem
Old Jan 31, 2004 | 05:57 PM
themyst's Avatar
themyst
Default UR Pulley problem
I got the crank pulley installed today... but I am experiencing some major squealing in the lower gears and lower rpms. when I'm cruising at highway speeds the sound disappears. What could be the problem?
Old Jan 31, 2004 | 06:12 PM
B2BigAl's Avatar
B2BigAl
Sound like the belt isn't on tight enough.
Old Jan 31, 2004 | 06:18 PM
2003z's Avatar
2003z
loose belt
Old Jan 31, 2004 | 06:27 PM
Ultimateone's Avatar
Ultimateone
yup its hopefully the belt.
Old Jan 31, 2004 | 06:49 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Happened to me as well on cold start up.... more belt tension will fix it for sure!!
Old Jan 31, 2004 | 10:04 PM
themyst's Avatar
themyst
any way I can adjust this myself without a jack? I got the pulley installed somewhat far away and I don't think I can make it out there for a while...
Old Jan 31, 2004 | 11:28 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Just involves taking the plastic cover off the bottom, loosening the tensioner pulleys, tightening the tension bolts, and then retightening the pulleys back. Theres a tension bolt/pulley for both belts. I'd recommend driving the car up on some stacked 2x4's to give you enough elbow room to do this. I used ramps and it took me 10 minutes to do before doing my oilchange.
Do a search for the pulley installation instructions for help.
Old Feb 1, 2004 | 12:03 AM
themyst's Avatar
themyst
crank pulley stopped squealing after a long drive around... odd. Maybe they just needed to break in?
Old Feb 1, 2004 | 07:14 AM
karlhungus's Avatar
karlhungus
Did you buy the shorter belt? I did the whole 3 piece set and (crank, water pump, and alt). Stillen sells the shorter belt for $45 and I have had no problems at all after a month. Very smooth and quiet.
Old Feb 1, 2004 | 07:20 AM
karlhungus's Avatar
karlhungus
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
