Clutch Recommendation
Old Apr 16, 2014 | 09:06 PM
T_R's Avatar
T_R
Default Clutch Recommendation
Hey guys I have an 03 350z full bolt on tuned. I have about 86k miles on the car. I'm replacing the clutch, I'm debating using a brand new stock clutch with a lightweight flywheel from Exedy or jwt? Could that work? I don't track it I daily the car and end up pushing the car a lot.
Thanks
Old Apr 17, 2014 | 08:06 AM
TuckerE36's Avatar
TuckerE36
There are countless threads covering this endless debate…
I have have the JWT combo. I don't track my Z but drive spirited occasionally. The JWT has a nice bite, stronger than the oem. As far as light weight flywheels are concerned. Do some research, there are a few options. If chatter annoys you then you'll just have to get over that.
Old Apr 17, 2014 | 08:24 AM
Nexx's Avatar
Nexx
jwt for na folks, gg move on
Old Apr 17, 2014 | 02:06 PM
Toneloc's Avatar
Toneloc
I recommend everything but factory...I narrowed it down for ya
Old Apr 18, 2014 | 07:54 AM
T_R's Avatar
T_R
Thanks guys looks like I'm gonna go with the jwt clutch kit anything I should be aware of?
Thanks
Old Apr 22, 2014 | 06:47 AM
DrKikRocks's Avatar
DrKikRocks
Nope .. Just installed mine. Just like TuckerE36 said^^ chatter which prob won't be that bad for you. Since your coming from the dual mass flywheel, which absorbs this noise,to a light weight flywheel you will notice "chatter". It's a bunch of science involved. Will rev up faster. Might have to get use to taking off a little. But other than that you'll love it. Trust me I'm a Doctor.
Old Apr 23, 2014 | 05:49 PM
Durden76's Avatar
Durden76
Just to clarify for you, if you go with the JWT clutch, you will also need their flywheel or a similar design. The JWT features a solid flywheel with a sprung-hub clutch. The stock Nissan equipment features a dual-mass flywheel and a solid-hub clutch. As far as I know you don't want to mix 'n' match.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
