Vented catch can fluid looks like cherry koolaid
Old May 5, 2014 | 01:49 AM
adamj27's Avatar
adamj27
Default Vented catch can fluid looks like cherry koolaid
But does not taste like cherry koolaid. Really though, any ideas on why? Smells oily, 100% sure it has nothing to do with ps fluid, I'm 6mt so no trans fluid other than the dexVI in my power steering.
I use actual German castol 0w30, maybe the byproducts involved are more red with GC oil?
I have an 06 revup with no OC issues either. This is very weird to me haha. Any ideas on the reason for this bright red condensate?
Old May 5, 2014 | 02:00 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Hmm awaiting someone else who has had this happen. Strange
Old May 5, 2014 | 05:44 AM
92K1500's Avatar
92K1500
Is it her time of the month?
Never seen oil turn red before....
Old May 5, 2014 | 09:46 AM
adamj27's Avatar
adamj27
I should mention I've let it settle for a few days, no layer separation either.
Old May 5, 2014 | 01:05 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
I use the same oil, to a Arc V1 can. mines brown. Oxidation in the catch can and reacting with the fluid maybe?
Old May 5, 2014 | 02:24 PM
adamj27's Avatar
adamj27
I'm assuming so. Especially since its mostly water based, I assumed the can was stainless though so idk why its rusting if that's the case.
Is yours vented though?
Old May 5, 2014 | 02:41 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
is there steel wool in there for baffling?
Old May 5, 2014 | 06:47 PM
adamj27's Avatar
adamj27
Nope, I think there's a single plate inside for baffling. No wool though. Also it's actually really light, I just pulled it off again to check the fluid today and it's lighter than I remember lol. Didn't have a magnet around to test for sure though.
Shouldn't be oxidation causing the red coloring though.
Old May 5, 2014 | 08:49 PM
npr350z's Avatar
npr350z
Do you live in a super humid place or have sucked in water?
Old May 5, 2014 | 08:57 PM
SR71's Avatar
SR71
Lead Super Moderator
Old May 5, 2014 | 10:17 PM
adamj27's Avatar
adamj27
Nope. Edmonton, our winter is dry and shitty and our summer is not warm enough (at least yet.. still snows sometimes lol) for any humid weather.
And I have no cold air intake sitting low, I was switching between the stock g35 revup airbox and the 350z revup box. the Z box is definitely not gonna suck up water, the G box might take a little rain through the hood but I doubt it would get past the filter anyway.
Originally Posted by SR71
I can assure you it doesn't taste nearly as delicious
Old May 6, 2014 | 08:24 PM
InZomniac's Avatar
InZomniac
I REALLY want an answer to this. Very intrigued. I'm betting someone put Hi C in it wo **** with you!
Old May 6, 2014 | 09:05 PM
npr350z's Avatar
npr350z
I've heard certian oils with with moisture can turn red...but that doesn't seem to be the answer.
Old May 7, 2014 | 11:14 AM
str8dum1's Avatar
str8dum1
either way, thats a TON of blowby. you sure some one isnt f'n with you!
Old May 7, 2014 | 12:53 PM
shakuya88's Avatar
shakuya88
Never seen that before, very interested to see why that happened. Maybe someone is messing with ya, or OP is messing with all of us. haha
Old May 7, 2014 | 02:41 PM
adamj27's Avatar
adamj27
Me too! I'm more curious than I am concerned lol.
I actually think this could be it.. I don't use typical oil. Only a handful of people bother with GC that is actually made in germany, it's easy to get here but I know in a lot of places the 0w30 is "made in US" or "Made in Mexico" etc.. not true GC.
I swapped to 0w40 GC though which is kind of a shitty test assuming they use similar additives, but we'll see in a couple weeks!
It's not blowby, this is a vented system. Just condensed oil vapor/fumes and water. I guess the water could be a sign of minor blowby since its from combustion but this was over a long *** period of time.
Haha I will definitely keep this updated over the next couple months as I try things out!
Old May 7, 2014 | 07:53 PM
DaveJackson's Avatar
DaveJackson
Master
^This.
That's such a bright, artificial red. It's not oxidation. Since it isn't settling, I'll guess it's ATF that someone put in
Old May 7, 2014 | 10:41 PM
adamj27's Avatar
adamj27
I can assure you it's not a prank. My car has a multi stage alarm, no one in my house knows anything about cars, and I have no enemies that have access to the engine bay lol. I do my own work so it's not a mechanic/tech problem. I'm pretty convinced it's the oil I use and if it turns red again, I'll swap to rotella or something dramatically different to confirm.
Old May 7, 2014 | 10:42 PM
adamj27's Avatar
adamj27
I am serious though, you can't even walk up to my car without a warning chirp. 3 feet proximity warning, reach in full alarm, shock sensor and full alarm if you're close enough (leaning on in without shock sensor activation).
My car is not tampered with evar
Old May 8, 2014 | 05:12 AM
eZg's Avatar
eZg
I was thinking some shmuck at a quickie lube may have done it by accident.......but since you do all your own work.......
you take ambien??? maybe sleep mechanic-ing???
