steering rack removal help
Old May 10, 2015 | 12:14 PM
dudeitsmartin's Avatar
dudeitsmartin
Exclamation steering rack removal help
trying to remove my steering rack. Has anyone done it before? some help would be appreciated. Im mostly confused when it comes to the lines. do i separate them from the rack before i pull it out, or keep it on the rack when i pull it out. Thanks
Old May 10, 2015 | 12:29 PM
92K1500's Avatar
92K1500
Depends. Why are you removing it?
Old May 10, 2015 | 02:26 PM
dudeitsmartin
to drop my subframe and to remove my upper oil pan.
Old May 10, 2015 | 02:32 PM
Conway_160's Avatar
Conway_160
I think you can remove the upper pan with all that still in there, or I hope at least since I have to do it in a month or so.
Old May 10, 2015 | 02:43 PM
dudeitsmartin
naw. Its all in the way. especially when you gotta tweak the starter.
Old May 11, 2015 | 10:22 AM
canadarob's Avatar
canadarob
Just replaced my rack:
- remove outer tie rods from knuckle (use a ball joint separator tool, a pickle fork will damage the outer tie rod).
- remove lower chassis brace
- remove clamp and low pressure line from the nipple on the rack (this is right below where the steering knuckle attaches)
- remove the high pressure line flare fitting (beside low side nipple, Use a flare wrench to prevent a stripped high side line)
- LEAVE lines on the body of the rack! Do not need to remove those.
- Mark steering knuckle in relation to rack splines and steering shaft splines
- Remove the two bolts clamping the steering knuckle to steering shaft and rack.
- Slide steering knuckle UP the steering shaft splines and OFF the steering rack (LOTS OF penetrate lube here! and two hands help if your on your back)
- Remove rack bolts and your good to drop.
Old May 11, 2015 | 07:51 PM
dudeitsmartin
thanks man!
Old May 11, 2015 | 07:55 PM
AARONHL's Avatar
AARONHL
get a factory service manual
but you can unbolt the rack and drop it down a little bit with the fluid lines connected
Old May 11, 2015 | 10:30 PM
dudeitsmartin
i do need one. I mostly need the one that most admins use to show torque specs and specifications for components. Thank you all, really great help!
sales@czp
Sep 23, 2019 03:30 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
