Suertech gear oil
Old Jun 30, 2015 | 04:30 PM
gearhead350's Avatar
gearhead350
Default Suertech gear oil
hey guys im changing the diff fluid in my 2003 350z base with an open differential with SUPERTECH API GL-5 SAE 80W-90, my question is if the supertech gear oil is any good? i hear a lot of people are using motul or red line...am i going to have any problems with this oil? thanks
Old Jul 1, 2015 | 10:31 AM
guitman32's Avatar
guitman32
It fine to use, go for it.
If you aren't tracking don't worry about the expensive stuff.
Old Jul 1, 2015 | 10:34 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
^^^ Word.
My shop - who also does a LOT of performance work - uses genuine Nissan GL-5 diff fluid. All good so long as it conforms to GL-5 standard in proper weight.
Old Jul 1, 2015 | 08:33 PM
terrasmak's Avatar
I used it in my 05, no problems. Sure I didn't do scientific tests, but....
For daily use under normal driving conditions (autobahn is a different story) super tech works great. I also ran the Supertech full synthetic engine oil in it, that car never burned a drop.
Old Jul 2, 2015 | 08:48 PM
CNunes_95's Avatar
CNunes_95
I've heard both positive and negative things about supertech. My Z isn't tracked, but I always like to use the highest and best quality lubicants for my Z. I would check out Redline MT-90 for the diff if you care about high quality oils like I do. I'm using Redline MT-85 on my tranny once I get my CD009 soon. Will most likely be more expensive, but it's a great oil.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
