Radiator fan does not shut off
Old Feb 22, 2016 | 03:02 PM
Freakville03's Avatar
Freakville03
Default Radiator fan does not shut off
Need some help. Replaced new radiator motor about 2 months ago and now it will not turn off and it is draining the battery.
Old Feb 22, 2016 | 03:44 PM
PP08HR's Avatar
PP08HR
Did this just start?
Have they've been working fine until now?
Were the parts aftermarket or factory?
Who installed the parts shop or buddy? Are you confident they were installed correctly?
Have you inspected the wiring to see if anything is crossed or shaved through the plastic coating and arching on something?
Old Feb 22, 2016 | 04:12 PM
Freakville03
Yes, this happen on Sunday (last time car was driven) and I went out today to start it and the battery was dead, so I put jumper cables on it and as soon as I did the fan came on.
The parts were from Nissan and I installed them myself. Easy bolt on and plug in connector. Just inspected all the wires coming off both fans and all are good with no chaffing.
Old Feb 22, 2016 | 04:40 PM
PP08HR's Avatar
PP08HR
Well dude I assume you replaced them because they weren't coming on right? An overheat condition?
Anyways, I'd take the connectors off and inspect the pins and see if anything is out of place, trace all the wiring for chaffing. If nothing then take them out and bring it back to the dealership for a new one.
Old Feb 23, 2016 | 03:13 AM
karlt's Avatar
karlt
Power for the fans cones through three relays on the IPDM E/R. The wiring diagram is in the ec.pdf section of the Service Manual. Look under DTC P1217 ENGINE OVER TEMPERATURE. One of the relays may be stuck closed, providing continuous power to the fans.
Old Feb 23, 2016 | 06:17 AM
jhc's Avatar
jhc
General & Tech Moderator
^^^ this. If your wiring is intact and correct remove relays one at a time and see if your problem stops. You may be able to isolate a bad relay with this.
Post up when you solve it. Gl
atf07
Sep 7, 2017 06:43 PM
phelannz
Feb 26, 2016 08:27 AM
potato
Cooling System
Feb 18, 2016 01:02 PM
shadowm891
Feb 16, 2016 12:13 PM
