Didn't mark drive shaft
Old Mar 7, 2016 | 05:03 PM
gossf's Avatar
gossf
Default Didn't mark drive shaft
So I'm in the middle of installing a jwt clutch and flywheel. I am using this guide along with the fsm:https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/292139-diy-clutch-install-part-ii-jwt-clutch.html
This guide didn't mention to mark the driveshaft during removal, but when researching rear bushing replacement I noticed that it was advised. I also recently noticed in the propshaft section of the fsm it indicates to mark the positioning. Well I've already removed the drive shaft and I didn't mark it. How screwed am I? Is there any way I can get it to line back up right? The need to mark it doesn't really make sense to me personally, what would you do if you got a new driveshaft, shouldn't it be balanced independently?
Old Mar 7, 2016 | 07:38 PM
terrasmak's Avatar
You will be fine, I have forgotten 5 or 10 times over the years
Old Mar 7, 2016 | 09:15 PM
mr. sparco's Avatar
mr. sparco
Didn't mark mine 3 years ago.
Old Mar 8, 2016 | 03:25 AM
travlee's Avatar
travlee
Master
all the clutches i have helped with, we never marked them
Old Mar 8, 2016 | 07:15 AM
rancor's Avatar
rancor
I think the drive shaft might have a mark on it from the factory.
Old Mar 8, 2016 | 10:48 AM
ninevoltz's Avatar
ninevoltz
I know that the drive shaft and differential pinion flange are marked at the factory to balance the run-out of the driveshaft with the run-out measured on the pinion flange. I assume this is to minimize vibrations at high RPMs.
Old Mar 10, 2016 | 02:34 PM
bjr's Avatar
bjr
I was worried about this too when I put in a different rear end. I thought how am I supposed to get the new rear end right when it hasn't been marked? Like everyone said it's going to be OK and would turn out to be OK for sure if you did pay attention. I think the key for you is to pay attention to the part where it says to put some pressure gently pushing the shaft up(?) when you are finger tightening the 4 bolts? That could turn out to be important too if it does really matter. Both are probably done to minimize any issue that could cause a problem.
Also there should be marks from the factory anyway- look one more time. And don't worry!
Old Mar 11, 2016 | 04:58 AM
ninevoltz's Avatar
ninevoltz
There probably isn't really enough manufacturing variation on these parts to really be noticeable, except at extremely high speed. All you need is a dial indicator and the service manual to redo the marks.
Old Mar 16, 2016 | 08:35 PM
allmycarsdie's Avatar
allmycarsdie
I did the same exact thing you did following the same exact post back in december. About 7k later and no ill effects
tjc6591
Apr 29, 2026 01:22 PM
IcanHaz
Mar 8, 2016 06:58 AM
Angel Dlc
Mar 7, 2016 04:50 PM
cacapisa
Mar 5, 2016 12:18 PM
