Radiator Replacement Question
Old Mar 21, 2016 | 08:59 AM
Roubaix46's Avatar
Roubaix46
Default Radiator Replacement Question
Purchased a cheap radiator replacement till I can save up for an aluminum one, and once it arrived I noticed two aluminum ***** on the bottom of it, looks like fluid may drain out of these? Might be a stupid question but what the hell are these? My old stock one did not have these and I don't know what I should do until I know what they are for. And help would be much appreciated.
Old Mar 21, 2016 | 09:19 AM
Zivman's Avatar
Zivman
my guess is you bought a radiator for an auto and you have a manual. those ports look like tranny input/output for a built in trans cooler
Old Mar 21, 2016 | 09:22 AM
Roubaix46's Avatar
Roubaix46
It says it's for either manual or auto. So somewhat confused still, don't know if I'm just supposed to block them off or what
Old Mar 21, 2016 | 09:30 AM
sportbiketed's Avatar
sportbiketed
Its an auto transmission cooler, just cap them off with some rubber nipples.
Old Mar 21, 2016 | 09:33 AM
Roubaix46's Avatar
Roubaix46
Okay, cool. If I just cap them, should I use a tight fitting cap or will just standard runner nipples work. I don't want anything to leak out of course
Old Mar 21, 2016 | 10:15 AM
canadarob's Avatar
canadarob
its a heat exchanger for auto transmission fluid to flow through the radiator but separate from coolant. Nothing will leak if you do not cap.
But I would cap as suggested to keep corrosion out. The cap wont face any pressure.
Old Mar 21, 2016 | 11:59 AM
dcains's Avatar
dcains
My '08 needed a replacement radiator under warranty. The car is a 6MT, but the dealer only had a 5AT radiator in stock, so I gave them the OK to installed that. I just put some vacuum line caps on the fittings, with a little silicone sealer to keep them in place. No issues after several years.
Old Mar 21, 2016 | 01:42 PM
CK_32's Avatar
CK_32
Nope your fine bud. I literally just bought one of those for my car as well. IIRC those are for a A/T fluid or something.
Mine is a M/T roadster and it runs fine. No leaks or caps needed. My only suggestion is put cardboard over the fins during install or something. I smashed a bunch of fins trying to bolt mine in. Then some more when I pulled my belts off from the wrench breaking loose.
Old Apr 1, 2020 | 03:14 PM
Bdjenk25's Avatar
Bdjenk25
Default Radiator with A/T cooler lines
I have manual transmission can I use the A/ T ports to cool my oil can? It has a radiator hose going to it?
Old Apr 2, 2020 | 10:30 AM
CK_32's Avatar
CK_32
you could try it, but I wouldn’t recommend it until you know it can stand the pressure. All these different fluid systems have different pressure caps. Oil, trans, coolant have higher or lower pressures so one may or may not hold the pressure for the other.
but if you want to try and test it go for it. Just be careful.
Old Apr 2, 2020 | 11:02 AM
Bdjenk25's Avatar
Bdjenk25
Default Radiator A/T cooling ports
Do you know what port is for fluid in and fluid out?
Gs_350z
Mar 16, 2020 03:34 PM
Xsellr8
Nov 5, 2017 10:06 AM
pilotstephen
Dec 4, 2012 03:17 PM
andrew16639
Nov 30, 2008 03:57 PM
NVthis350
Jun 22, 2005 12:51 PM
