Upper Oil Pan Replacement Help!
Old Apr 11, 2016 | 08:04 PM
kennyy's Avatar
kennyy
Default Upper Oil Pan Replacement Help!
Hey guys so I'm in the process of replacing the upper oil pan, everything under the car is off and the pan is ready to be taken out and replaced but I'm stumped. What's the best and easiest way to seperate the rtv holding the upper oil pan the to the block? Is there anything anyone has figured out as to what works best. I read the FSM and it says to use silicone cutter. I tried it but the rtv is solid as can be so the cutter doesn't really do anything. Any help?
Old Apr 21, 2016 | 11:58 AM
kennyy's Avatar
kennyy
Anybody?!
Old Apr 21, 2016 | 12:09 PM
CK_32's Avatar
CK_32
Try and heat it up a little and be gentle with a pry bar.
Thats how we use to get stubborn pans off when I worked at a shop. Just be sure to leave 2 or 4 bolts half screwed in if the car is lifted to keep it from falling to the floor.
Old Apr 22, 2016 | 04:52 PM
kennyy's Avatar
kennyy
Finally got it off, thank you for taking the time to reply to my post!
Old Apr 24, 2016 | 03:10 AM
35reilly's Avatar
35reilly
There are little pry points ( tabs) it's a b**ch!!! But coves off
Lithg
Jun 23, 2016 06:48 PM
#1Pussologist
Apr 14, 2016 09:30 PM
RobPhoboS
Apr 12, 2016 01:32 AM
