Throw out bearing?
Old May 25, 2016 | 06:19 AM
Nabice's Avatar
Nabice
Default Throw out bearing?
Hey quick question, i have a 03 350z touring 6 speed, and occasionally when i start up the car and keep the clutch in I'll get a grinding noise until i let the clutch out.
Then the car drives fine but if you rev the car with the clutch in you'll get the same noise/grinding and it'll go away once the clutch is let out.
Would it be the throw out bearing or pilot bearing? Doesn't majorly effect drivablity just want to fix it.
Old May 29, 2016 | 02:05 PM
gossf's Avatar
gossf
Most likely a throwout bearing, but have you had the clutch replaced or adjusted the throw on the pedal? Because when I replaced mine it actually was set to too much travel, causing the forks of the pressure plate to contact the clutch disk resulting in the symptoms you described.
Old May 29, 2016 | 02:26 PM
Nabice's Avatar
Nabice
Replaced the clutch no, but i just finished an engine swap from a g35 and the TOB was fine before and when i checked it before hooking the trans to the engine. How would i adjust the clutch pedal?
Old May 30, 2016 | 08:33 AM
gossf's Avatar
gossf
There's a rod that connects the pedal to your master cylinder, but if you've never adjusted it, that wouldn't be your problem.
Old May 30, 2016 | 08:59 AM
Nabice's Avatar
Nabice
I haven't but honestly i have no clue if the previous owner did adjust it.
Im gonna try to adjust it and see what happens cause i don'tthink its the tob i think its the pilot but im not for sure yet
7rrivera7
Sep 17, 2023 03:13 AM
Lithg
Jun 23, 2016 06:48 PM
MichaelaZ
May 6, 2016 10:18 AM
ashram
Mar 30, 2016 10:44 PM
gossf
Mar 24, 2016 05:43 AM
