(video) Vacuum leak and ticking sound
Old Jul 24, 2016 | 04:02 PM
openupitsdave's Avatar
openupitsdave
Default (video) Vacuum leak and ticking sound
I havent really looked at the motor of this car until now. I have a leaking air sound coming from the left side (passenger) of the motor. Not sure if its always been there or if its a vacuum leak.
Second thing is the infamous ticking sound which ive heard people say could be a few different things: lifters, timing tensioner, thrown rod, fuel position sensor, and the most popular answer is fuel damper.
Lastly, the driver-side fan doesnt work. Does it kick on at a certain temp or something? It was hot as ***** today...Anyway, heres the video:
Old Jul 24, 2016 | 07:18 PM
Conway_160's Avatar
Conway_160
Ok for fan, turn on A/C full blast once its warmed up if both dont come on you have a problem.
Left side could be either, brake booster hose or crank case.
Never heard of a fuel postion sensor.
Old Jul 24, 2016 | 08:56 PM
openupitsdave
Never heard of brake booster but ill find it....Also, where on the crank case would it likely be leaking?
Thanks Conway_160, im gonna check my A/C
EDIT: I dont think its the brake booster hose. The sound is coming from a bit south from there, and maybe 5-6 inches down
Old Jul 25, 2016 | 05:50 AM
Conway_160's Avatar
Conway_160
5-6" down? Im not aware of any vacuum hoses down there, unless you have a crack in your valve cover. Or the hose for the evap system, do you have any codes?
Old Jul 25, 2016 | 10:14 AM
openupitsdave
No codes. I just checked it out again. My car needs to be warmed up before you can distinctly hear it. It sounds like its coming right from the PCV valve but I tried putting my fingers around it to feel/listen for a leak but there's nothing. I think the leak is just below the PCV valve. But thats assuming its a leak....
Could anyone maybe check to see if they get the same sound? Car needs to be warm to hear it clearly..
I also tested my fans with the AC on with no luck. Only the passenger fan is spinning... SAD FACE. Where do I go from here?
Old Jul 25, 2016 | 03:05 PM
Conway_160's Avatar
Conway_160
Sounds like you have a dead fan, to verify this hook it up to a 12v source to see if it spins. If no go replace fan if spins its a relay or power wire some where.
My car isn't running and wouldn't be able to hear a leak over my blower sorry.
Old Jul 25, 2016 | 10:04 PM
openupitsdave
I want to test the fan. Any idea on which pins I need to hook up 12v to?
Old Jul 26, 2016 | 04:46 AM
Conway_160's Avatar
Conway_160
Sorry i dont, i will try to look it up today though.
Old Jul 26, 2016 | 02:36 PM
openupitsdave
I checked the air leak again today and I think it is actually the PCV valve but I cant seem to fix the leak. Im starting to wonder if thats just how the PCV sounds normally. It would be awesome if someone can confirm this for me.
I got Torque linked again today (been a while because my car has been sitting for over a year). A few readings it gave after warmup while idling were: Coolant - 90C, Vacuum - 24.5, idle @ 600rpm..
I also have had a fault code P1065 which is faulty ECM. http://www.engine-codes.com/p1065_nissan.html Im not sure if this was from when I installed LED tail/turn lights. I got Torque and tested for codes at the same time I installed the LEDS so im not sure if that code was there before or not.
Old Aug 2, 2016 | 02:02 AM
openupitsdave
bumping in hopes someone could check if they get a leaking air sound coming from the PCV valve area also
timmays350
Tuning
May 25, 2016 05:03 PM
vp85
May 5, 2016 09:04 AM
David Womacks
May 4, 2016 05:47 PM
Speertjuhh
May 3, 2016 08:20 PM
Total D
North Central
Apr 28, 2016 09:29 PM
