Engine shuts off while driving
Old Aug 3, 2016 | 07:42 PM
terrj's Avatar
terrj
Default Engine shuts off while driving
I dont know if its a huge coincidence or its the cause of it but the car's shutting off randomly while im driving ever since i hit a huge pot hole and slammed the car really hard. I notice it only happens when i press down the clutch to shift or coming to a stop with the clutch also press down of course
There's no code , no light , no recall for the cam sensor , i already called the dealership to make sure and the car doesnt have trouble starting right up after. Im pretty sure something got loose when i slammed the car hitting that damn pot hole but i just dont know what it is, any thoughts ?
Car has 88k miles with oem clutch , K&N intake , plenum spacer . That's it
Old Aug 4, 2016 | 04:42 AM
terrj's Avatar
terrj
pump ?
Old Aug 4, 2016 | 05:17 AM
Highway Riding's Avatar
Highway Riding
Had a similar situation with a bad battery connection. Car would shut off when coming to a complete stop and the battery would move. Fixed terminal connection fixed the issue for me.
Old Aug 4, 2016 | 06:30 AM
RedBullRR's Avatar
RedBullRR
Had similar situation. Clean the MAF. They sell a spray at your local autozone. Corrected my low idle when I came to a stop, and the random shut offs when I would stop or put in nuetral. It's def a good idea to do this anytime you clean your filter.
Old Aug 4, 2016 | 11:58 AM
terrj's Avatar
terrj
Thanks guys, hopefully its that simple
Old Aug 4, 2016 | 12:12 PM
terrj's Avatar
terrj
Checked and the battery connection is solid. Theres no play, and like i said, it only happens when the car's hot. If only it throws a damn code
Old Aug 5, 2016 | 07:26 AM
Highway Riding
Missed the hot part. I would clean the MAF like others have mentioned.
Old Aug 5, 2016 | 08:44 PM
terrj's Avatar
terrj
I will try tomorrow, hopefully thats all it is.
Old Aug 5, 2016 | 09:03 PM
KingBaby's Avatar
KingBaby
Hardest Setting
if not the easy stuff, your Z may have a busted BCM or harness
Old Aug 6, 2016 | 05:47 PM
terrj's Avatar
terrj
Well it is a 13 years old car after all, im not surprised when things like this go wrong anymore haha. I just hope it throws a code or something so i can pin point the problem
Old Aug 31, 2016 | 08:28 PM
terrj's Avatar
terrj
UPDATE : The culprit was my TB , it was extremely filthy so after a thorough cleaning the problem went away . Hopefully this helps anyone who has the same problem.
Make sure you disconnect the NEGATIVE plug on the battery first before cleaning the TB and leave it unplug for a whole day . I did that and i had no high idle or CEL when i turned the car on. Cheers !
Old Aug 31, 2016 | 11:03 PM
StevSam's Avatar
StevSam
Don't forget to relearn if there's idle issues, good job!
Old Sep 3, 2016 | 08:31 PM
terrj's Avatar
terrj
Didnt have to do anything at all. I guess i got it right the first time, extremely lucky
Old Jun 28, 2021 | 08:45 PM
Nubz's Avatar
Nubz
Default Same issue
what is a TB?
Old Jun 29, 2021 | 02:00 AM
travlee's Avatar
travlee
Master
Originally Posted by Nubz
what is a TB?
Jeebus.....
It's a throttle body
daxman
Apr 19, 2016 06:42 AM
Bilazaurus
Mar 15, 2016 02:36 AM
