Lower Rad Hose...
Old Sep 17, 2016 | 08:29 AM
dragon11689's Avatar
dragon11689
Default Lower Rad Hose...
Hey Guys,
Anyone have experience with the gates lower rad hose? I installed my upper and lower and then had issues with overheating and leaking coolant. I did a cooling system pressure test and found out that the top of the lower rad hose got cut by one of the engine belts.
I'm ready to replace it to see if I just needed to shift the hose a bit to one end or if it's a defect in the hose design. I've used gates products before and haven't really ran into any issues. Any advice, suggestions and experiences are appreciated. Thanks.
Old Oct 29, 2016 | 03:48 AM
black93supra's Avatar
black93supra
when you are fitting the hose make sure to give enough clearance for the pulley on that side. Had the same issue. Just back the hose off just a bit and make sure the clamps are tight and you should be good to go.
Bak3rme
Oct 10, 2016 07:50 PM
Speednz
Sep 18, 2016 02:07 PM
tedzilla
Sep 15, 2016 06:40 AM
ARRRT
Sep 14, 2016 12:45 PM
Dloyd350
Sep 11, 2016 12:29 AM
