Fluid help
I am going to change the transmission and rear end fluid. It's a 2003 350z. Does anyone know what the volume and kind of fluid for both. I think I know what fluid I want but I can't find the volume
From what my chart is saying, its the following:
Transmission [6MT] - 6.1 Pints
Rear Diff - 3 Pints
You can use 75w-90 for both, or if you're pushing a good amount of tq, or drive it hard you can upgrade to a 75w-110 for the rear diff.
Rear Diff - 3 Pints
Practically speaking, you'll need 3 1/2 quarts of Redline MT85 (GL-4 spec) for the manual transmission. It's a synthetic lubricant with the viscocity specs that match factory recommendations, as well as sufficient friction engineered in to allow the syncros to work well. For the rear diff, you'll need a different lubricant; about two quarts of a 80-140W GL-5 pressure enhanced fluid.
Here's a link to a thread on the subject: https://my350z.com/forum/engine-driv...ssion-oil.html
