Nitrous reliability
Old Jan 30, 2017 | 02:56 PM
Z33E's Avatar
Z33E
Default Nitrous reliability
So I've been eye balling the idea of getting the ZEX kit for my 04 z which has your normal bolt ons minus a tune, but I have a few questions before pulling the trigger
1- HOW hards the install
2-how reliable will my car stay with 55/75 shot if I do it like once a month, this cars gonna be DD for next 5+ years god given.
3- will my weak *** trans be able to handle that with stock clutch without blowing up in a year.
Old Jan 30, 2017 | 03:44 PM
Conway_160's Avatar
Conway_160
6 speed nissan 350z tranny weak????
Good sir you need to read, its one of the strongest transmissions I've ever seen.
Old Jan 31, 2017 | 07:31 AM
rancor's Avatar
rancor
3- will my weak *** cd006 trans be able to handle that with stock clutch without blowing up in a year.
3 - I think that depends more on how you shift than the power you are making. The less stress on the synchros the better.
Old Feb 2, 2017 | 07:14 AM
SikkyMFG's Avatar
SikkyMFG
Vendor - Former Vendor
A small shot like that should be fairly reliable. I would just check the AFR on nitrous to make sure your fuel jet is correctly sized.
I'd also recommend putting 1 stage colder plugs and making sure you run only 93 in the car.
With all of that considered it should be pretty reliable.
Old Feb 2, 2017 | 07:16 AM
Z33E's Avatar
Z33E
Sweet I live in northern Texas so I got 93 everywhere that's all i use maybe I'll finally pull the trigger on nos
