Car won't run
Old Feb 5, 2017 | 09:38 PM
lambodz350's Avatar
lambodz350
Default Car won't run
Hi everyone I got a 03z last year I took it to a show and race. The car started smoking bad whe I first pulled it off the trailer so I took it parked it in the show. When it came time to take it down the track I cheeked it all over everything seemed fine. On the way over started to smoke again. So I took it straight to the trailer and took it home. When I got home to unload it it would not start. So we got it in the garage got it up in the air found out the oil return line from the turbo had twisted like 10 times have no idea how this had happened all claps were tight. Fixed the line started to pull things apart found oil in cylinders 5 and 6. All the other cylinders were good so I got those cylinders cleaned out. I replaced all the plugs. It's getting spark and pulled the fuel injectors and it's getting fuel. Also replaced the crank sensor and cam sensors. I'm now at a lose if anyone has had this problem or got any answers that would be awesome thank you
Old Feb 6, 2017 | 05:02 AM
knuckles899's Avatar
knuckles899
I would get a compression and leakdown test done to see if the rings got smoked.
Old Feb 6, 2017 | 03:45 PM
lambodz350's Avatar
lambodz350
ok will I still need to do that if the car will idle but as soon as you hit the gas it kills it
Old Feb 8, 2017 | 06:57 AM
knuckles899
Some of the more knowledgeable members may know....you could have another issue but a compression leakdown wouldn't hurt to know. Generally oil in the cylinders could be worn rings or valve seals....it's hard to say.
