Please help
Old Aug 29, 2017 | 12:42 PM
Lega_Z's Avatar
Lega_Z
Default Please help
So the other day I finished up a clutch kit with my dad the flywheel is aligned and everything went back in smooth.. went to test drive the car and now when I give it gas to rev up the motor it barely gets rpm and when driving won't go over like 5 mph. Is it the CPS???
Old Aug 29, 2017 | 01:41 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Sounds like limp mode. Pull codes and get back to us.
Old Aug 29, 2017 | 01:42 PM
Lega_Z's Avatar
Lega_Z
I will. If it helps I was told that since the battery was unplugged for a few days it may need an ecu reset
Old Aug 29, 2017 | 03:17 PM
Lega_Z's Avatar
Lega_Z
Ok so I pulled the codes and didn't think to write them down. However one code I got was a camshaft over compensation or something like that??? Is it a camshaft position sensor? Could something have got bumped or banged when the transmission came off of the motor? I cranked it up earlier and it idles low and when given gas the rpms barely climb and it acts like a lack of fuel. Could it possibly be the throttle body??
Old Aug 29, 2017 | 04:29 PM
Lega_Z's Avatar
Lega_Z
Codes came back and they are P0327 P0011 and P0021
Old Aug 29, 2017 | 07:41 PM
Lega_Z's Avatar
Lega_Z
So I'm thinking I may have to pull the transmission again and check the flywheel :/
