I need some help
Old Sep 1, 2017 | 04:14 AM
Brokeboyz's Avatar
Brokeboyz
Default I need some help
so my 2003 engine blew and im looking to swap it with another engine and i did some research on what year engine i could interchange it and some said 2003-2005 engines could be interchangeable and some said no. So my question is can i swap a non rev up 2005 vq35de in my 2003 z without needing another tranny and ecu
Old Sep 1, 2017 | 04:51 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Yes.
Old Sep 1, 2017 | 05:16 AM
Brokeboyz's Avatar
Brokeboyz
Default Thanks
thanks man because I kept trying to research it and some said I could and some said no I didn't want to spend 1k on an engine and then needing to buy a tranny etc.
Old Sep 1, 2017 | 07:26 AM
Atreyu'z 350
No problem.
Old Sep 1, 2017 | 08:15 PM
Conway_160's Avatar
Conway_160
You can use ANY RWD DE motor.
Old Sep 2, 2017 | 09:46 AM
ridered929rr's Avatar
ridered929rr
You can basically put any motor you want in it with the right harness/CPU. Just saw a 70 Cuda with a duramax diesel putting out 700+ hp. All about what you want to spend but to keep tranny/ecu any DE Motor as mentioned above would work
