Trouble starting help please!
Old Sep 6, 2017 | 04:12 PM
jcrow's Avatar
jcrow
Default Trouble starting help please!
I have an all stock 04 base manual 350Z. Today it has started having trouble starting. It cranks over fine then immediately shuts off when the rpm's drop down to idle, however if I give the gas pedal a little love tap before the rpm's drop it starts and runs fine. This did not start until I went to get gas because the gas light was on and it said like 4 miles till empty, at first I figured it was cause the gas level was so low. The battery is less then a year old and shows normal voltage and no codes, I'm guessing maybe fuel pump? Any other ideas? And is the fuel pump a pain to replace?
Old Sep 7, 2017 | 04:01 AM
travlee's Avatar
travlee
Master
my guess is camshaft sensors
Old Sep 7, 2017 | 06:14 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Do you hear the fuel pump prime itself right before you start the car? btw(if you're doing this)riding on a quarter tank of gas or under constantly isn't particularly good for the fuel pump, as it likes to stay submerged in fuel to cool itself.. No, it's not hard to replace either.
Old Sep 7, 2017 | 08:10 AM
jcrow's Avatar
jcrow
Yes I can hear the fuel pump the more I think about it I don't think that's the issue and I don't normally let it get that low this morning leaving for work it started fine if it is the cam shaft sensor how bad is that to replace?
Old Sep 7, 2017 | 08:22 AM
travlee's Avatar
travlee
Master
10 minutes tops per sensor, with a 10 mm socket. i have always been a stickler for OEM sensors, but the price difference may sway ya
Old Sep 7, 2017 | 08:28 AM
Atreyu'z 350
OEM ONLY.
Old Sep 7, 2017 | 08:30 AM
Atreyu'z 350
So your car's fine now?
Old Sep 7, 2017 | 04:22 PM
jcrow's Avatar
jcrow
Update I have learned it only dose it on warm starts this morning I left for work and it started up fine then from work to the store it was finethen from the store to the house it did it again and had to give the gas pedal a little love tap to start it
