VQ35DE Ticking - Engine Noise Video
Old Dec 18, 2017 | 08:13 PM
deG35's Avatar
deG35
Default VQ35DE Ticking - Engine Noise Video
Hello everyone!
Is this engine noise normal? I'm new to Nissan/Infiniti & the engine seems very loud to me.. I'm hoping it's not valvetrain/shim related or worse, thanks for watching!
Old Dec 19, 2017 | 12:30 AM
CK_32's Avatar
CK_32
Sounds like lifter tick. Normal for the most part. A lot of Z's have it if not all.
Old Dec 19, 2017 | 03:19 AM
travlee's Avatar
travlee
Master
Old Dec 19, 2017 | 06:08 AM
deG35's Avatar
deG35
Default Thanks!
Thanks guys, I'm going to listen to some other cars in person to compare. The car has 68K miles & always serviced by the dealer at the correct intervals, I believe the original owner complained about ticking noise when pulled up to the side of a building back in 2012 with 48K on the car & the dealer said it was normal. That's actually how I noticed it, picking up medicine from Walgreens.
Old Dec 20, 2017 | 05:25 PM
RENFRO's Avatar
RENFRO
Sounds normal to me. Pretty sure my 03 DE does the same.
Old Dec 20, 2017 | 06:43 PM
deG35's Avatar
deG35
Default Thanks!
Thanks for the reply! =)
I did end up comparing it to another 2006 G35 Sedan the dealer had, and while that one wasn't as loud as mine they basically sounded the same. I'm not used to DOHC engine or this engine design.
Old Dec 20, 2017 | 07:00 PM
bealljk's Avatar
bealljk
I'm pretty sure mine does ... talk to Conway about engine ticks - he knows best!
Old Dec 22, 2017 | 01:19 PM
Conway_160's Avatar
Conway_160
Lol, unfortunately I do. I should be able to tell you exactly want is causing mine in a few weeks.
Mine is isolated to passenger side under the intake manifold on the #2 cylinder. Mine is so loud it's making my knock sensor go crazy. I get 500 count at 10/15% throttle going to 3k rpms.
Old Dec 22, 2017 | 03:38 PM
bealljk's Avatar
bealljk
You've been through a lot ...
I'll try to get a video of mine but I got a few pieces off the engine that gotta go back on first...
Old Dec 23, 2017 | 09:23 AM
Conway_160's Avatar
Conway_160
Here is my tick
Old Dec 23, 2017 | 10:18 AM
CK_32's Avatar
CK_32
That's not a tick, that's a motor slap^ Lol
Also yours came from the block area, OP's seems faint and from the intake mani which is usually just lifters and such.
Old Dec 23, 2017 | 03:49 PM
bealljk's Avatar
bealljk
engine tick - hope it helps
Old Dec 23, 2017 | 06:37 PM
Conway_160's Avatar
Conway_160
When i put a stethoscope on it, it's defiantly louder at the cylinder head and not the block. Would that still be motor slap?
Old Dec 24, 2017 | 06:18 PM
CK_32's Avatar
CK_32
I'd still say yea. Your video sounds a LOT like my friends when they throw bearings or rods. If you notice the other 2 videos theirs is rotational. Yours is all the way through the firing order.
If that's normal that's one hell of a lifter tick. Probably the worst I've heard yet.
Old Dec 24, 2017 | 07:20 PM
Conway_160's Avatar
Conway_160
FML!
Old Dec 24, 2017 | 09:18 PM
bealljk's Avatar
bealljk
FML!
Is the shop going to address this when they do the other work? Bring your phone / computer to the shop and show them these videos?
Dont restart your build until this is fixed!
Tell those funkers to fix it! You paid to have it done right!
Old Dec 24, 2017 | 09:41 PM
CK_32's Avatar
CK_32
Your oil should be a huge tell if you actually did.
You should have some massive shavings or straight up metal parts in your oil pan. That's the first thing I would do.
If the shop does open the block make sure the pistons aren't hitting your valves or over extending the walls.
Old Dec 25, 2017 | 03:19 AM
Conway_160's Avatar
Conway_160
Nothing crazy when I changed my oil, there was a very slight metallic shimmer in the oil but I figure that's from the rings setting. There was no metal pieces on the lower pan when I pulled it off i added two magnets to my oil filter to catch the metal though.
I told them to listen to it once the car is not leaking. I'm not taking the car home until they address the noise.
Old Dec 25, 2017 | 09:28 AM
CK_32's Avatar
CK_32
Yea that's normal from a new engine which is why you want the change the oil at 500, 1000 and 3000 miles. "Engine break in".
But yea I would have them address that as well. Everything is just a guess until someone actually gets in there and looks. But like I said that patter sounds really similar to when my friends blew their sht.
I'm still trying to track down the video my buddy sent me of his thrown rod when he got home the day he blew it. Also does it continue when you rev it? If it goes away it's not as serious. If it gets worse or stays there yea something is 100% wrong.
Old Dec 25, 2017 | 12:43 PM
Conway_160's Avatar
Conway_160
It stays the same regardless of temp, I can't hear it when I'm setting in the car so I don't know what's going on when there is load on it. But when it free revs the tick speeds up with the some.
I should have put my go pro Mic in there while I drove it around to see how it sounds at certain rpms.
