Her 350Z Failed inspection.
Old Feb 13, 2018 | 03:45 PM
Atreyu'z 350's Avatar
Atreyu'z 350
dude, go test your battery.
Old Feb 13, 2018 | 07:44 PM
TangoAlphaZulu's Avatar
TangoAlphaZulu
I'll give that a shot....
Old Feb 14, 2018 | 06:14 AM
Atreyu'z 350
Originally Posted by TangoAlphaZulu
>EDIT<. My previous response in this spot may have indicated the problem was solved. Alas it is not.
I returned to the inspection place this afternoon, and the problem is still not fixed. Same four items are reading as incomplete. The last time the battery was disconnected was when the car was worked on in November. I am stunned three months of driving is not sufficient to CMPLT all the SRT stuff. I am also baffled at how the Inspection station can read the data port, but code readers at three different part stores and mechanics cannot communicate at all.
The service manual (at least the part quoted by Karl says:
"If a vehicle is rejected for a State emissions inspection due to one or more SRT items indicating “INCMP”, use the information in this Service Manual to set the SRT to CMPLT”."
Does this refer to something specific that can be done in the shop to set an INCMP to CMPLT, or is the procedure they refer to driving around?
Is there any way to know the status has changed to CMPLT other then a trip to the inspection station to get the codes read again?
Yeah, like I said. You can buy a handheld OBDII scanner from an auto parts store or ebay/amazon.
Old Feb 14, 2018 | 07:07 AM
TangoAlphaZulu
No codes are being generated. The report from the inspection facility shows that shows that much. What several have said, and that I am finally understanding is the computer is not finding anything wrong. It is just saying the System Test is not yet complete. A test not finished is not the same thing as something wrong.
The OBD port is the second part of the problem anyway. Even if I had a reader, three places (two part stores and a mechanic) have tried their scanner, and none of them could communicate with the car. The port was dead as far as they could see. It is a mystery how the Inspection station communicates with the car. The only thing I can think of is the inspection station powers the car from it's equipment, while handheld scanners require power from the car.
So, it is back to the question, how do I know the test has successfully completed if the car says nothing is wrong?
Old Feb 14, 2018 | 07:11 AM
TangoAlphaZulu
Got the battery tested this morning. According to the Autozone battery tester, the battery has 91% capacity, which according to their battery testing gadget is a bad battery.
I will have to replace the battery just to eliminate this possibility.
I have trouble seeing how this could be the cause of the problem. The car has no problem starting. The starter cranks hard with no hint of fading. If this bad battery has no problem starting the car, why is it not good enough to keep the computer happy?
At least changing the battery will give me access to the fuse panel in that compartment. Maybe that is where fuse 34 is hiding. Maybe that will get the ODB port working again.
Old Feb 14, 2018 | 08:01 AM
Atreyu'z 350
You won't. Unless you get that port working, or take it back to the place, the dealer, or someone with Consult II.
Old Feb 14, 2018 | 11:52 AM
TangoAlphaZulu
Problem Solved. Car has PASSED inspection.
I found the fuse for the OMBII port, or at least found where it was supposed to be. Someone had pulled the fuse and stuck it in a blank spot on the fuse block. With the fuse in its proper place I headed back to the parts store. When I got there I decided to get a second opinion (test) on the battery. This time, the technician kept getting "poor connection" on his battery tester, so no test.
Moving on to the OMBII port. This time, with a working port, we got "ECM Backup power supply fault. Probable Cause:
1. Open or short circuit
2. Poor electrical connection
3.Failed ECM
Yep, #2 was screaming at me. Pulled the battery terminals, cleaned the crap out of them, went for a 35 minute drive, and went straight to the inspection station. This time it PASSED.
So, just because a battery connection is good enough to pass the butt-load of amps for a starter motor, does not mean it will pass the milliamps needed to keep the computer memory from dropping out. I should have known better.
Thanks to everyone for your help,
Jeff
Old Feb 14, 2018 | 11:53 AM
KornerCarver's Avatar
KornerCarver
I think it is about time to take the car to a dealer and have them diagnose the problem.
Old Feb 14, 2018 | 03:27 PM
Atreyu'z 350
3.Failed ECM
Jeff
Because the starter motor does what it's told and the ECU does what it wants. Praise the universe.
Old Feb 14, 2018 | 06:09 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I scrolled through 2 pages and never found the GF pic. WtF is wrong with you guys...
Previous owner probably had it tuned for test pipes and the sensors disabled. Takes about 50 miles of driving once the battery is discounted for the sensors to be back to ready on the stock ecu.
JERZ350
May 26, 2016 07:05 AM
britalia
Sep 22, 2009 06:54 PM
Car vs. Driver
Mar 16, 2009 07:48 AM
mifastZ
North East
Apr 3, 2007 08:39 PM
mamasz007
Dec 18, 2004 07:56 AM
