P1167, P1166, P1147, P1146, P0159 - Failed Inspection.
Old Mar 14, 2009 | 04:01 AM
Car vs. Driver's Avatar
Car vs. Driver
Default P1167, P1166, P1147, P1146, P0159 - Failed Inspection.
Ok, so my thought is that I have all these codes because of my test pipes. I do have the anti-foulers installed, but that clearly isn't working.
Now my question is if I might just have bad rear O2 sensors or not. Any thoughts on how I can get rid of my CEL? I have to get my car tagged/inspected before the end of the month and it won't pass with a CEL.
Thanks ...
Old Mar 14, 2009 | 06:06 AM
twitch579's Avatar
twitch579
Put the cats back on and then have it inspected.
Old Mar 14, 2009 | 07:58 AM
Car vs. Driver
That would work if I had a set ..
Old Mar 14, 2009 | 09:03 AM
vthao's Avatar
vthao
You probably don't have bad 02's...this is why if you live in a smog state you should always keep your oem parts. Luckily there are some cheap ones in the classified section, just search. Best of luck.
Old Mar 15, 2009 | 04:20 AM
Car vs. Driver
Turns out that both of my rear sensors were loose .. weird. As far as inspection goes, they only check the ECU for codes, no sniffer test. So as long as there is no CEL, I pass.
Old Mar 15, 2009 | 11:21 AM
rcdash's Avatar
rcdash
You can pass the OBD! Just know the regs for your state...
Old Mar 16, 2009 | 07:48 AM
Car vs. Driver
Yep, I know them. The whole problem was the CEL, as long as that's not on and there are no codes coming from the ECU I'll pass.
350z_z33.
Jul 3, 2017 04:01 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
h8redlights
Sep 11, 2015 07:57 PM
speedtrialbrian
Oct 10, 2003 08:31 AM
LaterApex
North Central
Oct 6, 2003 06:06 AM
