Differential rebuild
Old Mar 12, 2018 | 04:43 PM
bcoffin23's Avatar
bcoffin23
Default Differential rebuild
I busted the input pinion bearing on my NISMO LSD. The input pinion is totally seized.
Anyone know a rebuild kit?
I found the bearing online, but think they may be other components on the input pinion shaft that may need replacement.
Old Mar 12, 2018 | 07:17 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry- I've never heard of a rebuild kit for a NISMO LSD. In most cases, it means starting over with a fresh unit.
Old Mar 12, 2018 | 07:36 PM
bcoffin23's Avatar
bcoffin23
The diff itself is fine. It’s the input pinion on the pumpkin that busted.
Old Mar 18, 2018 | 10:56 PM
guitman32's Avatar
guitman32
For actual parts its just a nut, oil seal, 2 bearings, pinion shim (reuse if it isnt damaged) and crush spacer...not that many parts but you need quite a few tools to get the job done.
Check the FSM it outlines everything in great detail.
carboyanno
Jun 14, 2016 05:46 AM
ebadai98
Drivetrain
Nov 11, 2012 10:16 AM
LSX-PWR
Jul 2, 2009 08:48 PM
