Aftermarket Throttle Body Affecting MAF Sensor?
Old Apr 16, 2018 | 02:41 PM
bcoffin23's Avatar
bcoffin23
Default Aftermarket Throttle Body Affecting MAF Sensor?
Hi All,
My last two track days have ended with a P0102 (Low MAF Voltage) code and the car in limp. I unplugged the battery for 30min + put in a brand new MAF sensor + housing, but same issue.
Previous owner installed an '06 intake with velocity stack and a 350evo Bored Throttle Body. The car has been dyno - tuned professionally through UpRev (not tuned by UpRev themselves)
Anyone here run into MAF issue when they went aftermarket with their throttle body?
If I go back to a stock throttle body, will I need a re-tune or can I do a throttle body relearn?
*The car runs fine around the street or at 70% on the track. Only after a few laps of pushing the car will this code get thrown*
Old May 11, 2018 | 11:24 AM
bcoffin23's Avatar
bcoffin23
Found the issue. It was a shortage in my MAF wiring from the MAF plug to ECU. The shortage was where the wiring goes through the firewall to the ECU.
Doc_Z
Oct 1, 2024 08:42 PM
Jbotto1
Nov 8, 2017 03:54 PM
QuadCam
Mar 8, 2007 12:21 PM
ROME
Aug 8, 2004 07:22 PM
