Wideband O2 sensor depth affecting reading???
Is it possible that you could get extra rich reading from a wideband O2 if the sensor is not deep enough in the pipe........
Ever since I redid my setup, my wideband is reading about 1.0 rich all the time. I had to have some exhaust work done, and they put a new bung in the exhaust......well, I took a look at it today and it seems to be a thicker (deeper) bung than I used to have. This bung would seem to not allow the wideband O2 to go as deep into the exhaust tubing. I am talking about probably only 1/4" less depth into the pipe. what do you guys think?
on
At least for narrowbands the depth of the sensor has no effect on the reading. Worst case scenario it would delay the response time of the O2 sensor to a exhaust mixture change so a O2 at the manifold with pleny of exposure to the exhaust stream might show a reading a few milliseconds sooner then one mounted where your sensor is but the end result (the reading) should be no different unless there is an exhaust leak around the wideband..
on
Originally Posted by QuadCam
i just don't know why all of a sudden it is off so much.
UltimateSleeper
Trust me, it can't possibly make a difference...the diameter of the whole INSIDE the sensor core that lets in the gas to be analyzed is the size of a human hair. Hence, ther is no way that an increased/decreased flow of air due to the depth in the pipe can make a difference.
No worries there bro.
