03 350z NEED HELP ASAP!! Intermittent unresponsive throttle when in gear
Old May 26, 2018 | 11:50 PM
Jhef91's Avatar
Jhef91
Default 03 350z NEED HELP ASAP!! Intermittent unresponsive throttle when in gear
Need some help, got an 03 6 speed base model. Will randomly have an unresponsive throttle only while in gear or with the clutch pressed. If I take it out of gear and let out the clutch it will respond but if I put it back in gear it still is unresponsive. Note there are no codes or TCS or slip light due to it being a base model. Also clutch is not slipping at all.
Old May 28, 2018 | 05:45 PM
terrasmak's Avatar
I would check the tail lights first, I bad bolt can trigger throttle cut. Next would be the brake light switch checking.
M_Cruz813
Jan 29, 2016 02:30 PM
maXmood
May 5, 2012 07:36 AM
soporific88
Apr 2, 2011 01:36 PM
350zna
Sep 19, 2008 05:36 AM
andypandy
Mar 21, 2006 12:17 PM
