Chattering when cold
Old Jul 4, 2018 | 06:36 AM
Nfsundrgrnd's Avatar
Nfsundrgrnd
Question Chattering when cold
First time posting here and i need some help figuring out a problem with my 350z. I recently replaced my clutch and flywheel to a JWT 14 lb lightweight flywheel and clutch. The techs who did the job messed up and put some GL5 oil in my transmission and i didn't notice until about 5 days later when my transmission would grind when going into 5th. I brought the car back and they put some Factory Nissan GL4 and the grinding went away. But now, there's a chatter around 3 - 4000 rpm when driving the car cold. It lasts for 5 - 10 mins and slowly fades away when warming up. The sound is almost like the flywheel chatter but at higher rpms, or maybe even a bad throwout bearing like noise. Any idea what this could be and what could fix it? Thanks.
Old Jul 4, 2018 | 07:35 AM
coletrickle74's Avatar
coletrickle74
Could be anything you mentioned. Send it back
Old Jul 4, 2018 | 10:21 PM
mr. sparco's Avatar
mr. sparco
Its been a while IIRC anything less than 19 lbs and there will be noise. The lighter the flywheel the louder the chatter at lower rpms. If you suspect something else, then definitely take it back.
Old Jul 5, 2018 | 10:31 AM
Heel Til I Die's Avatar
Heel Til I Die
I noticed a marked increase in clutch chatter when I switched over to the JWT 14 lb flywheel. It's about half the weight of the stock dual mass flywheel. The "cement mixer" sound is one of the things you'll have to live with. If you want less chatter, you should go to a heavier flywheel.
can'tZme
Mar 30, 2010 11:43 AM
doreamon50
Feb 18, 2006 01:13 PM
ep3turbo
Nov 28, 2005 10:33 AM
Andys'Z
Mar 17, 2005 02:25 PM
srobert910
Oct 8, 2003 12:23 PM
