Cylinder 2 misfire please HELP
Old Feb 5, 2019 | 09:53 PM
gearhead350's Avatar
gearhead350
Default Cylinder 2 misfire please HELP
Please help. Yesterday i drove my Z in kinda heavy rain and the car started bogging and threw these codes....
P1144 HO2S1 Bank 1
P1164 HO2S1 Bank 2
P0302 Cylinder 2 misfire
I cleared the codes and let the car sit for a few. After sitting i went out and drove it when the roads were dry and it stopped bogging and no o2 sensor codes. However the car still misfires at between idle and 1.5k rpm. Its not a constant misfire it just kinda hiccups every few seconds. I did all the regular misfire checking stuff by switching around the coils and plugs and it stayed at cylinder 2. So i replaced the injector today and still didnt fix it. I also did a compression test on cylinder 2 and it was perfect....The CEL does not come on but i have the scanner plugged in and the misfire code doesnt pop up until 10 minutes of the scanner plugged in and the car idling. Im so lost on this and feel like all this had to do with the water...
Is it possible i shorted something in the wiring harness? If it did short how would that only cause cylinder 2 misfire? Please HELP
Old Feb 6, 2019 | 04:40 AM
travlee's Avatar
travlee
Master
try swapping coil packs with another cylinder... see if it follows it
Old Feb 6, 2019 | 09:16 AM
gearhead350
I did all that stuff already
Old Feb 6, 2019 | 09:54 AM
travlee's Avatar
travlee
Master
did you check the plugs.
Old Feb 6, 2019 | 09:55 AM
travlee's Avatar
travlee
Master
how many miles, ever changed the plugs
Old Feb 6, 2019 | 09:57 AM
gearhead350
Motor has 52k miles and plugs are 3 days old...like it said in the post im pretty sure it has to do with the water. I switched plugs around switched coils around, replaced injector, checked compression and nothing changed. So im assuming i shorted something
Old Feb 6, 2019 | 10:03 AM
travlee's Avatar
travlee
Master
or there is still moisture somewhere
Old Feb 6, 2019 | 10:05 AM
gearhead350
Possibly, im just so lost with this, the misfire didnt start until it threw those o2 codes but the o2 codes are gone
Old Feb 6, 2019 | 10:21 AM
travlee's Avatar
travlee
Master
spray connectors with wd40,,, drive around for a bit
Old Feb 6, 2019 | 10:22 AM
gearhead350
Cylinder 2 coil connector?
Old Feb 6, 2019 | 11:23 AM
travlee's Avatar
travlee
Master
yeah, that will displace the water that is in there
Old Feb 6, 2019 | 11:29 AM
gearhead350
Ill give that a try, thank you!
Old Feb 6, 2019 | 01:19 PM
gearhead350
I just read my long term fuel trims and bank 1 is at 102% bank 2 is at 100% and neither are changing
Black350z9972
Jan 25, 2014 07:36 PM
burubuduy
Sep 27, 2010 02:29 PM
RJ's Z
Jun 28, 2010 07:35 AM
350zz053
Sep 9, 2006 04:10 PM
350Zzzz
Dec 16, 2003 08:12 PM
