Axle Stub Issues
Old Apr 10, 2019 | 12:05 PM
Noodlez's Avatar
Noodlez
Question Axle Stub Issues
After reading codes for my ABS light, I found that it was due to my passenger side rear wheel speed sensor. After investigation, I found that the axle stub is no longer sealed into the side of the dif like it should be. I read on some other threads about how all I needed to do was order a new circlip to reinstall.
My question is how do I reinstall the axle stub? Does the clip on onto the axle stub and then into the side of the dif? Or do I fit the circlip into the groove first and then try to slide the axle stub in?
I tired both ways and had trouble getting the splines to match up. Both ways I tried it the axle stub would bottom out on the clip before the splines even had a chance to line up. I tried hammering it into place but had no luck.
Any ideas on how to get it reinstalled? Do I need to take out the whole dif to get enough leverage to hammer it in?
Any help would be appreciated.
Old Apr 21, 2019 | 06:23 PM
guitman32's Avatar
guitman32
Make sure there isnt already a clip inside the differential that didnt come out with the axle
Budders
Jan 6, 2019 06:35 PM
Gavin Pancirov
Jun 25, 2018 04:22 PM
3hree5ive0ero
58
Dec 9, 2012 12:28 PM
koren
May 4, 2011 08:37 AM
wadd3456
May 12, 2003 03:31 AM
