R8 Coilpack in a VQ
Old May 24, 2019 | 09:08 AM
Cracka350's Avatar
Cracka350
Default Result: Negative
Well well it was a nice thought. But even with a stem swap the 370z coils aren't plug and play. Both coils are made by the same manufacturer. The second picture is the 370. The third is the 350 OEM. With the new ones installed, the car started quickly enough but was misfiring a lot. I pulled the coils, reinspected them, cleaned the contacts and reinstalled them. No change. Additionally, 370 packs fitted with 350 stems sit too high such that they cant cover the spark plug wells or even be bolted down. For you lurkers reading this in 2021, dont waste your time with coil packs from other cars.
Old May 24, 2019 | 09:15 AM
bealljk's Avatar
bealljk
Appreciate the effort Cracka ... thanks for doing the leg work and sorry it didnt work out...
Old May 24, 2019 | 09:35 AM
Cracka350's Avatar
Cracka350
Since I still have to pull them out anyway I'll test to see if any of the packs are bad. But I'm honestly still curious about the R8 packs. Too bad they're 4-pin. They wouldn't fit the 350 motor.
Old May 24, 2019 | 08:20 PM
DarkZ03's Avatar
DarkZ03
Sorry it didn't work, does make me wonder about the splitfire and okada coils tho. I know it won't be a lot of power but smoothness and efficiency is what I would be looking for lol.
Old May 25, 2019 | 08:51 AM
jv350z's Avatar
jv350z
thanks for trying. I'm still wondering about the R35 coils. the video made it sound like those coils could be taken apart, similar to what you did with the 370Z coils (I guess all the Nissan equipped are pretty similar in form-factor).
Old May 25, 2019 | 05:30 PM
DarkZ03's Avatar
DarkZ03
If the R35 are shaped like the Z34 then it will be the same issue
Old Sep 9, 2019 | 08:35 AM
superpreditor's Avatar
superpreditor
I just installed VQ37HR coils in my VQ35de powered 350Z, they were a direct swap besides changing the "coil boot" and needing longer bolts to bolt the coil down....🤷🏿*♂️
I'm running a Haltech Elite 2500, not sure if the stock emu is the issue.
Old Sep 9, 2019 | 08:37 AM
superpreditor
They bolt down and cover the spark plug hole just fine, you just need longer bolts.
Old Sep 16, 2019 | 12:17 PM
Cracka350's Avatar
Cracka350
I never came back to update. I had everything installed but accidentally switched the plugs between the aft two drivers side cylinders. That caused the misfire. If I can figure out the length and width of replacement bolts I'll reinstall and post results. But I've had my hands full restoring a VF750, SV650 as well as replacing ball joints tie rod ends diff bushings etc. Its been a long summer..
Old Oct 28, 2019 | 08:56 PM
George Abraira's Avatar
George Abraira
5 Year Member
Default R8 coil Article
Click here for the R8 coil review
Old Mar 6, 2020 | 01:59 PM
Cracka350's Avatar
Cracka350
Default Findings
I compared pictures of the 350 and 370z ports. They look compatible. Anyway I ordered a used set off of eBay this morning so I'm officially going to test the concept.
I'll post my findings and a couple of pulls for comparison. Street, not dyno. What am I made of money?..
The short of it: Throttle feels more awake.
At last I reinstalled the 370 coils. Originally I accidentally swapped plugs for the aft 2 drivers side coils which caused the misfire. I put them in yesterday. Rather than ordering new bolts for mounting, I just plugged them in. The tight fit and inflexible wiring harness will likely eliminate any risk of poor connection. The spark plug also connects to a flexible spring that travels through the boot. Since the whole point of the mode is to increase spark I wasn't expecting a noticeable difference. But while driving home on the highway I felt like the 10% throttle I used to maintain speed was a little more responsive. Likewise hammering up 2nd and third on a local road felt a little more lively. This may just be confirmation bias, but improved combustion could explain this change. If the cpu were tuned, I think these could make even more of a difference. All in all I'm pleased, but would love to see actual numbers.
Old Mar 21, 2020 | 04:40 PM
ScaryFatKidGT's Avatar
ScaryFatKidGT
370Z coils and GT-R coils are the same thing and our a very good coil, they are better than 350Z coils but they are 14mm not 17mm, Audi coils are 17mm and have the same dwel as 350Z's so the swap works.
Old Mar 21, 2020 | 06:45 PM
jv350z's Avatar
jv350z
Originally Posted by ScaryFatKidGT
same dwel
Old Aug 1, 2020 | 09:49 PM
Tran251's Avatar
Tran251
Sorry Conway. Bringing this thread back to life.
https://www.50ignite.com/blog/techni...z-coils-re-co/
either way. I’m saving to get the ign1a coils. People on haltech group in fb reports gaps of .031 with 800whp got me sold on the ign1a
Old Aug 1, 2020 | 10:03 PM
DarkZ03's Avatar
DarkZ03
I still want to see the R8 coils vs OKD coils.
Old Aug 2, 2020 | 01:55 PM
Conway_160's Avatar
Conway_160
Sooo r8 coils ftw..
Old Aug 22, 2020 | 08:48 PM
Tran251's Avatar
Tran251
Originally Posted by Conway_160
Sooo r8 coils ftw..
yeah. There were pretty good gains just plug n play without even touching timing yet.
if you read that link it’s pretty good.
The wiring is pretty straightforward.
I ordered some oem mercury optimax coils. I’m going to print some brackets or just bolt one side to the valve covers.
once you get them wired in and hooked up please post the results. (Butt dyno or real)
I think ballengermotorsports have the pigtails.
Old Sep 1, 2020 | 06:21 PM
  #38
Tran251's Avatar
Tran251
Just got some ign1a coils and got the dwell settings from haltech map vs rpm n voltage.
the dwells they recommend are pretty high.
Over 6ms at 200kpa if I remember correctly.
I’ve been on solidworks cad drawing up some VQ35 ign1a brackets. Haven’t seen anyone have these in the forums yet. I guess I’ll be the first to go. I’ll report back in a couple weeks once I get these wired up and mounted.
I’m using accel 8mm wires for this. I’m trying to keep them as short as possible.
Comes with vise crimpers like back in the day.
Old Sep 2, 2020 | 01:49 PM
  #39
Conway_160's Avatar
Conway_160
Can't wait to see this!
Old Nov 9, 2020 | 06:57 AM
  #40
Z33Garage's Avatar
Z33Garage
subbed for results
