Plenum Spacer and strut brace
Old Aug 27, 2019 | 07:52 AM
Blackskiies's Avatar
Blackskiies
Default Plenum Spacer and strut brace
Im looking at plenum spacer but apparently there are three sizes 5/16 1/2 and 5/8. I am looking at the thicker ones 1/2 or 5/8 but am worried about if the strut bar will still fit.
Old Aug 27, 2019 | 09:30 AM
bealljk's Avatar
bealljk
only the 5/16" fits under the strut bar.
Old Aug 27, 2019 | 01:12 PM
Heel Til I Die's Avatar
Heel Til I Die
The plenum spacer should come with spacers (aka washers) to install under the strut bar mounts so it will clear if you go larger.
Old Aug 28, 2019 | 05:48 AM
hulkout's Avatar
hulkout
This. My motordyne came with spacers.
Old Aug 28, 2019 | 07:41 AM
jhc's Avatar
jhc
General & Tech Moderator
Aka "fender washers"...
You use these to shim the brace a little higher, the bolts are plenty long enough.
Old Aug 28, 2019 | 02:56 PM
Blackskiies
I thought the spacers were for the 6 bolts in the middle (inside the plenum)?
Old Aug 28, 2019 | 03:28 PM
Heel Til I Die
Stack the washers at the four mounting points on each shock tower to raise the strut bar off the plenum.
The plenum spacer should have also come with longer bolts to account for the spacer. I believe mine came with some rubber washers to seal the upper plenum.
I wasn't quite satisfied with the OEM bolts so I went with some longer ones. I used M10-1.25 X 30mm J.I.S. Small Head Hex Flange Bolts and reused the nut on each side.
Old Aug 28, 2019 | 03:52 PM
bealljk's Avatar
bealljk
both ...
if you ask me tower brace spacers are jank as hell! If I saw these installed on someones car I would think less of them and their build.
Old Aug 28, 2019 | 07:10 PM
DarkZ03's Avatar
DarkZ03
Lol, this is one of the many reasons I swapped to a velocity manifold, and also have the Carbing brace.
djmike350z
Oct 28, 2014 10:05 AM
surfo
Apr 12, 2011 08:12 PM
N0 F34R 1488
Jan 22, 2008 07:58 PM
Conrado III
Aug 30, 2007 10:02 AM
bverschage
Feb 23, 2006 01:03 PM
