Engine build on the way Dynosty or IPP
Old Sep 7, 2019 | 04:33 PM
That_hrz's Avatar
That_hrz
Default Engine build on the way Dynosty or IPP
Well sad day for me due to a flat foot shifting error with my arc features causing the car to over Rev a bearing is done and car has a pretty bad rod knock. My plans were to start a 3.7hr build but unsure if I can trust a stock bottom end again. So for the guys that have built blocks short/long from either Dynosty or IPP how have they held up ?? My goals are only 700rwhp. I could care less about head work just wanting the built short block with probably Manley vhr rods and custom 11.1CR HR pistons. Any input welcomed!
Old Sep 7, 2019 | 04:43 PM
travlee's Avatar
travlee
Master
Dreamer thread
Old Sep 7, 2019 | 06:44 PM
That_hrz's Avatar
That_hrz
Not sure what a dreamer thread is just asking how have people’s blocks held up. I’ve only heard of one guy complaining about his failed motor from IPP. But if you have no input please don’t comment at the end of the day I’m going to end up going whatever route I go
Old Sep 7, 2019 | 08:01 PM
bealljk's Avatar
bealljk
I had a pretty good experience with Kyle at IPP. I bought a stage 3 back in 2009 and put about 30k miles before I spun a bearing myself. I fault Kyle / IPP 0% as there were many contributing factors and I definitely drove the car hard over the 10 years or so I had it.
Nothing wrong with Dynosty - I would surf both their websites and see what package you like best.
Old Sep 8, 2019 | 12:25 AM
DarkZ03's Avatar
DarkZ03
Also do research on the engine 11:1 ain't getting you 700 whp, too high for 700hp of boost and the highest NA is barely into the 500s with 15:1.....that being said my vote goes to Dynosty.
Also flat foot...playing Russian roulette, someone's been watching lowtek lol
Old Sep 12, 2019 | 03:02 AM
Conway_160's Avatar
Conway_160
11.1:1 is fine for 700 if you plan on running using E, 93+ Water Meth, or 100+oct. A lot of cars now a a days run higher compression and add boost. You will NEED a good tuning software ie... a standalone.
When trying to get high power do the head work, power is made in the head not rotating assembly!
Old Sep 12, 2019 | 06:13 AM
iideadeyeii's Avatar
iideadeyeii
Goals should be measured in 1/4 time not horsepower. That being said. What's your budget for this 700whp build?
Old Sep 12, 2019 | 06:18 AM
travlee's Avatar
travlee
Master
op be like
Old Sep 12, 2019 | 06:24 AM
That_hrz's Avatar
That_hrz
Sorry I should have been more specific about my set up I currently run boosted performance twin scroll single turbo kit making 566hp 480tq @13psi before it blew up so it will have no problem making 700 with the 3.7 bottom end. And I never tried to use flat floot shifting ever I just had the arc features for rolling anti lag and stand still burn outs but it was the rolling anti lag that malfunctioned.
Old Sep 12, 2019 | 07:21 AM
That_hrz's Avatar
That_hrz
Budget is going to be 7k just for the built block which is very doable as IPP has fully built blocks for around 5.6k.
Old Sep 12, 2019 | 07:23 AM
That_hrz's Avatar
That_hrz
Yes my car is already boosted and Uprev tuned
Old Sep 12, 2019 | 07:28 AM
That_hrz's Avatar
That_hrz
Yes thank you For the info this is not an N/A build car currently makes over 500s boosted with stock 10:1 CR so I’m more than confident a 3.7 11:1 can make 700 with the same 13psi
Old Sep 12, 2019 | 07:41 AM
That_hrz's Avatar
That_hrz
Originally Posted by travlee
op be like
Build is gonna be more than your bank account contains that’s all you need to know 😂😂.
Old Sep 12, 2019 | 07:46 AM
travlee's Avatar
travlee
Master
yeah, no
Old Sep 12, 2019 | 07:54 AM
That_hrz's Avatar
That_hrz
yeah, no
Thanks for all your input sir anyway found a nice 26k mile motor to drop in until I figure out what route I’m going
First motor swap wish me luck
Old Sep 12, 2019 | 08:07 AM
travlee's Avatar
travlee
Master
its not that hard to swap, will be kinda time consuming
Old Sep 12, 2019 | 08:50 AM
bealljk's Avatar
bealljk
elevation vs. sea level
Old Sep 12, 2019 | 09:58 AM
iideadeyeii
Tomato, tomato
Old Sep 12, 2019 | 10:37 AM
bealljk's Avatar
bealljk
Tomato, tomato
sea level ET +1 second = elevation ET … done and done
Old Sep 12, 2019 | 01:59 PM
DarkZ03's Avatar
DarkZ03
So you want to make 134whp with a .2L bump and 1 extra CR. A bit ambitious but ok, good luck. Also uprev is not a standalone, and not suitable for high powered applications
