Help with diagnostic
Old Sep 14, 2019 | 12:33 AM
Bertiskyys's Avatar
Bertiskyys
Default Help with diagnostic
I need some help here.. long story short I replaced my water pump. I slipped a tooth on the timing chain. Took everything off, set it right ( I believe) put it all back together car starts and has a hella bad idle and dies. Only code is p0113 witch is the maf.. one of the wires is broken.. could this be the cause of my bad idle and basically dying?
Old Sep 14, 2019 | 02:08 AM
813_350Z's Avatar
813_350Z
Could be, but screwing up timing usually ends in disaster. The only way to find out is to fix the sensor and see what happens.
Oh, and use only OEM. Other sensors cause problems.
Old Sep 14, 2019 | 05:22 AM
travlee's Avatar
travlee
Master
Somethings broken, could it cause my issues..... well yeah. Jeebus
Old Sep 14, 2019 | 09:09 AM
Bertiskyys's Avatar
Bertiskyys
Thanks guys. Its just annoying having done all the work to find a small wire broken. Just making sure I didnt need anything else
Old Sep 14, 2019 | 09:22 AM
jhc's Avatar
jhc
General & Tech Moderator
Use a butt-type crimp connector on the MAF wire, then use heat shrink wrap to make it waterproof.
Bertiskyys
Oct 13, 2019 06:04 PM
jpadron1995
Jun 11, 2013 06:54 AM
mastercater7
Jun 2, 2009 12:14 PM
etl45
Jan 26, 2009 06:56 AM
