Rough idle!
Old Jan 23, 2009 | 11:11 PM
etl45's Avatar
etl45
Default Rough idle!
okay so i have a mild rough idle!
help me PLEASE!
i cleaned MAF sensor, and air filter on my CAI~
also changed spark plugs to ngk iridiums!
also tried fuel injection cleaner!
help anyone!
thanks
oh.. i also mis shifted at high RPM on 3rd gear to 2nd gear? could i have meesed up something that may have cause this rough idle?
i just think it wouldnt have cause the car drives so fine.. just the idle part.
OH i also reseted ecu and relearned everything!
cant think of anything else!
Old Jan 23, 2009 | 11:16 PM
surfcity40's Avatar
surfcity40
How did you clean the maf sensor? just buy a new one. you apparently broke it.
Old Jan 24, 2009 | 02:52 AM
etl45's Avatar
etl45
why do you aasume i broke it?
i cleaned it DUE to the rough idle..
NOT rough idle came after cleaning.
help please~
Old Jan 24, 2009 | 03:01 AM
Z04's Avatar
Z04
help please~
because after reading your numerous "help me please" threads it is obvious you have no clue WTF you are doing when it comes to cars just step away from it and take it to the dealer
this could be your problem right here:
https://my350z.com/forum/maintenance...dle-reset.html
Old Jan 24, 2009 | 10:12 AM
etl45's Avatar
etl45
if you cant help.. dont reply maybe..?
anywaise like i said in the op.. i already did that. relearn everything.
and if all of us could just take it to the stealership, why would i even use the forum??
thanks anywaise though
Old Jan 24, 2009 | 10:43 AM
Z04's Avatar
Z04
that was help. you really need to stop messing with it before it becomes totally undriveable. obviously all you have done to it has not worked (most of it was totally unecessary) so you can read all you want on here but even that will not help you.
Old Jan 26, 2009 | 06:56 AM
VO...'s Avatar
VO...
Administrator
I am having this thread locked also. Please ask your related questions in the thread you have already created:
Consider this a warning, along with the couple others I have already given you. Next infraction will result in time-out in the sandbox:
https://my350z.com/forum/6864734-post7.html
https://my350z.com/forum/6864689-post7.html
liqalu04
Jan 2, 2022 12:58 PM
ablaine
Nov 29, 2016 10:13 AM
bneumann
Oct 7, 2015 12:16 PM
Darkspy
Sep 7, 2015 09:09 PM
