Manual to Automatic transmission Swap
My bad. It's late.
Gearbox
ECU
differential
drive shaft
auto cluster
shift linkage
brackets
You will also need a good idea of wiring to get it to work properly
Whether going from auto to manual or vice versa it is a much better idea to just sell and buy the car with the trans you want unless you are emotionally attached. It is way too much of a hassle doing the swap, plus it is costly and kills resale. A manual Z is highly sought after so you should have no problem selling and buying an auto. Hey, you may even come out ahead.
Gearbox
ECU
differential
drive shaft
auto cluster
shift linkage
brackets
I couldn't have said it better.
It tends to go the other way because owners want a stick shift that bad. I strongly recommend saving yourself the trouble and swapping out for a Z that already has one.
Hey guys, I really need some help here. This isn't my first language so I don't even know how to make a good research for my issue.
I have a 2003 Z (vq35de) with bad tranny, I just bought a 2008 transmission and I'm trying to figure if it fits.
Really appreciate your help.
350Z/370Z Tech Moderator
