Engine misfiring, no check engine, recent sensor replacement
Old Dec 23, 2019 | 08:12 PM
Cujucuyo's Avatar
Cujucuyo
Question Engine misfiring, no check engine, recent sensor replacement
Hey guys, I replaced my crankshaft and crankshaft sensors recently (Hitachi CPS0005 and Hitachi CPS0008), this was probably two months ago, and I haven't driven out much since then, suddenly the engine starts misfiring (sounded like a V8 which was nice but it's not good, lol), I've had his happen before and it was due to a bad coil which fixed the issue once replaced, however at that time I got a check engine light which told me of the issue, I don't have any check engine light coming on.
The other odd thing is that the engine does this for a couple of minutes, 4-5 and then runs normally, it happened twice in a 2 hour drive I did today, very bizarre; Any ideas?
I heard you have to relearn the position sensors or something along those lines, maybe I missed a step after replacing the sensors?
Old Dec 23, 2019 | 08:41 PM
813_350Z's Avatar
813_350Z
Try using a scanner to see if you have DTCs. Codes may exist, but may not have triggered the CEL just yet.
Consider replacing those crankshaft and camshaft sensors with actual OEM sensors. Unfortunately, the symptoms you are describing are common when replacing these sensors with aftermarket models and occurs quite frequently. Although it is common to try to save a few bucks by not getting OEM sensors, it can create additional problems. It is a common case of "spend alot once, cry once".
Old Dec 23, 2019 | 09:16 PM
Cujucuyo's Avatar
Cujucuyo
Thanks I'll check with my OBD2 tomorrow see if anything comes up; The sensors are OEM, Hitachi makes them for Nissan:
Hitachi p/n CPS0005 angled sensor = Nissan 23731-AL61A driver side intake and passenger side exhaust (angled sensor) + Hitachi p/n CPS0008 straight sensor = Nissan 23731-6J90B driver side exhaust and passenger side intake (straight sensor)
Old Dec 23, 2019 | 11:39 PM
813_350Z's Avatar
813_350Z
You're right. That was my mistake lol.
As for the relearn, I don't believe there is one (or at least I have not had to). I replaced my sensors a few years ago and they were just remove, install, and good to go. No relearn required.
Let us know if you have any codes come up and what they are. If none then we will consider other options.
Old Dec 24, 2019 | 01:43 AM
Cujucuyo's Avatar
Cujucuyo
I just checked right now and no codes, did an erase even though there weren't any, re-scanned, no codes again; Seems like whenever the RPM go below 1000 it starts misfiring (not all the time, it's just that most of the time I've noticed this it's while I'm stuck in traffic) and as soon as I accelerate it normalizes after a bit; Spark plugs are brand new NGK Iridium (changed them in September) that I got from Amazon; The other culprit could be the Mass Air Flow sensor and it needs to be cleaned, but the thought that keeps nagging on the back of my head is when a friend whose a mechanic told me that if I was to replace the Crankshaft/Camshaft sensors there's an option in advanced OBD2 gadgets that has a "relearn alignment procedure".
Old Dec 24, 2019 | 02:12 AM
813_350Z's Avatar
813_350Z
Did this occur out of the blue? Or it did occur immediately following a repair/mod.
Have you gone through to ensure you don't have any cracked/broken/disconnected vacuum hoses?
I have never heard of, seen, or done any relearn procedure after swapping camshaft/crankshaft sensors. I could be mistaken, but just saying.
Old Dec 24, 2019 | 02:47 AM
Cujucuyo's Avatar
Cujucuyo
Out of the blue, after I changed the sensors it was pretty smooth, that was 2-3 months ago.
Old Dec 24, 2019 | 03:07 AM
rustyschopshop's Avatar
rustyschopshop
definitely double check vacuum lines, would not hurt to check fuel pressure. Actually doubting fuel pressure since it goes away at higher rpm but doesn't hurt to check.
LiVn_It_UP
Jul 23, 2018 01:24 AM
AJLUVHERZ
Jan 26, 2016 05:01 PM
Dust
Sep 15, 2015 02:08 PM
blackfairlady
Dec 9, 2007 06:56 AM
