Advice on Smoke From Engine bay
Old Feb 5, 2020 | 02:46 PM
theshrink1's Avatar
theshrink1
Default Advice on Smoke From Engine bay
Overheating and now smoke from engine on start-up. See pic for the area of the white smoke. Car overheats when driven and will smoke from circled area on start. Oil all around the area. Can I drive this to mechanic <5 miles>. Thanks.
diagnostic and advice.
Old Feb 5, 2020 | 03:12 PM
813_350Z's Avatar
813_350Z
Hard to tell from the pic, but if that is the valve covers then you have two separate issues. The valve cover is leaking and you have oil dripping down on the exhaust manifold, which is being burnt off and causing smoke. No big deal, but your valve cover gasket will need to be replaced to fix that. Safe to drive.
I'd figure out why you are overheating though. That will be your biggest detriment.
engiNERD350Z
Dec 7, 2007 01:29 PM
ipcheck
Oct 28, 2006 02:50 PM
donricouga
Cleaning & Detailing
May 27, 2005 04:56 AM
Bubble
Mar 20, 2005 06:20 AM
maximumsportZ
Jan 26, 2005 02:04 PM
