Softer durrometer upgraded transmission mount
Old Feb 26, 2020 | 09:20 PM
ScaryFatKidGT's Avatar
ScaryFatKidGT
Default Softer durrometer upgraded transmission mount
So I bought a crappy drift Z and am going through replacing a ton of stuff, all front lower suspension bushings, rear diff bushings, new coilovers.
One thing I'm concerned about is replacing the diff bushings I would like to also replace the trans and motor mounts but have rear a lot about an obvious immediate increase in NVH, I can take a little, especially in the steering wheel but don't want constant engine and gear noise, this car isn't exactly an Audi to begin with... I replaced the motor mounts on my subaru and other than hearing the starter more when starting the car it has been fine.
I see in a lot of old posts 2007-2012 Z1/Torque solutions/Avid offered a softer durometer bushing, specifically 60a vs 75a, does anyone know if anyone still offers these or should I stick with the factory trans mount and just do the Z1 motor mounts?
Old Feb 26, 2020 | 09:28 PM
ScaryFatKidGT
Also are there any bushings on the trans subframe mount or the front subframe? As I will be removing and reinstalling these.
Old Feb 26, 2020 | 10:31 PM
813_350Z's Avatar
813_350Z
Go with Z1 poly motor and trans mounts. NVH is not that bad vs the benefits they bring.
813_350Z
Aug 5, 2021 02:45 PM
calvin.w
Sep 2, 2020 05:23 PM
KRK.Z33
Feb 20, 2020 09:20 PM
bishop_98
Wanted
Jun 20, 2011 01:11 PM
speedracer05
Aug 17, 2010 09:42 PM
