Throwout Bearing noise
Old Jun 18, 2021 | 03:17 PM
Mattedg_man's Avatar
Mattedg_man
Default Throwout Bearing noise
My throwout bearing is making a little noise. I assume it will get worse with time. Should I be concerned about that failing and look to replace it or will I only have to deal with a noisy bearing which I can live with
Old Jun 19, 2021 | 06:14 PM
dkmura's Avatar
dkmura
General & DIY Moderator
It's always helpful to post total mileage on your Z, as well as how many miles are on your clutch/flywheel/throwout bearing when asking a question like this. I suspect you'll need to replace this noisy bearing sooner than later.
Old Jun 21, 2021 | 06:39 AM
Mattedg_man
Should have included it earlier but my Z is at a ripe 140K. Just wondering if I should be worried about the bearing failing or if ill just have to put up with some noise
Old Jun 21, 2021 | 07:41 AM
iideadeyeii's Avatar
iideadeyeii
Put up with the noise. Very unlikely it will ever completely fail. I've had so many cars with that same issue. My 350z does it right now and the bearing was brand new.
It's about a 4hr job to change the clutch if you know what you are doing( a friend is very helpful to get it back up) I wouldn't worry about it
Revived_Signs
Jun 18, 2014 05:46 PM
domenic
Dec 10, 2005 10:03 AM
