Vq35 connecting rod ?
Old Oct 2, 2021 | 02:36 AM
g35/1958's Avatar
g35/1958
Default Vq35 connecting rod ?
Hello , I am putting a vq35de g35 motor back together. My question is, when installing the piston onto the connecting rod is there a front mark on the connecting rod.
Thanks in advance. G35/1958.
Old Oct 2, 2021 | 03:06 AM
RobPhoboS's Avatar
RobPhoboS
What rods are they ?
My Manley ones didn't have a specific chamfer, so it didn't matter.
Old Oct 2, 2021 | 11:42 PM
g35/1958's Avatar
g35/1958
They are the stock nissan connecting rods. They may not have a front and rear , but I thought I had better ask. Cheers.
Old Oct 4, 2021 | 04:00 AM
RobPhoboS's Avatar
RobPhoboS
In the FSM, on page EM-120 it does note about the OEM rods having a front facing mark, so probably best you look at this firstly.
Old Oct 5, 2021 | 01:56 AM
g35/1958's Avatar
g35/1958
Thanks RobPhobos, does it give any other information? I don't have the FSM. Can anyone else help research this as I need to get this motor back together. Or is there a better section on this forum to find the answer. The con rods have an oil hole drilled through the con rod that is directed towards the underside of the piston. So this hole could be on top or bottom depending which way the con rod is installed. Please help.
Old Oct 5, 2021 | 02:05 AM
RobPhoboS's Avatar
RobPhoboS
https://www.nicoclub.com/nissan-service-manuals
Old Oct 5, 2021 | 07:02 AM
g35/1958's Avatar
g35/1958
Thanks RobPhoboS, That has solved my problem. I had actually installed 4 of the pistons on the rods incorrectly. Thanks again,
1sik7
Jul 6, 2012 06:48 PM
thor0331
May 24, 2011 02:35 PM
Frostydc4
Oct 15, 2005 08:36 PM
