Rough cold start startup issue
Old Oct 5, 2021 | 05:43 AM
JUSTINC2001's Avatar
JUSTINC2001
Default Rough cold start startup issue
2008 350z problem
So this car has 170k miles
on cold start it sounds like it about to die for a few seconds you’ll start it up and some days it’s worse than other but I’ve noticed it’ll get down to like 250 rpm and sounds like it has somewhat a cam and then it’ll shoot to 2k rpm after a couple seconds
If you shut the car off and start it when it warm it’s perfectly fine I feel like it could be a sensor but it’s not throwing a sensor code
It only has one code and that it’s running lean on bank 1 so what much I check for first also I have an afr gague and it always has the correct readings of high 14 low 15 if that helps
Old Oct 5, 2021 | 07:43 AM
JUSTINC2001
Another thing they say when they try and floor it it takes a second to actually go it’s also a automatic
Old Oct 5, 2021 | 12:08 PM
jhc's Avatar
jhc
General & Tech Moderator
Test the resistance (ohms) on your coolant temperature sender on the intake manifold. cold and hot. If it's 0 or infinity it's worn out (bi-metal switch). Check ATF fluid level, if it's topped off tranny might need service.
Old Oct 5, 2021 | 02:32 PM
JUSTINC2001
any idea if it’s not them things ima check them but the coolant temp sensor I read the symptoms of one failing and it doesn’t sound like that I also don’t belive it has anything to do with tranny because I worded it wrong it’s not a shudder it’s like it’s hesitation but I’ll still check it
Old Oct 6, 2021 | 04:59 AM
jhc's Avatar
jhc
You stated it idles very rough when cold and is fine after warmup. Exactly a temp sender symptom. Where did you "read" your info?
Old Oct 6, 2021 | 05:52 AM
JUSTINC2001
well it doesn’t stay a rough idle it’s only starting it the first few seconds when cold it’s rough and there’s no check engine light other than the sometimes a bank 1 too lean code but the afr gague doesn’t show it runs lean it runs perfect
Myblackzzz
May 31, 2015 05:01 PM
nerv81
May 30, 2010 10:10 AM
03brembo
Sep 25, 2009 02:31 PM
athenG
Nov 16, 2008 07:49 PM
booger
Apr 27, 2006 03:00 AM
