2003 350z car won't start!!!!
Old May 30, 2015 | 09:00 PM
Myblackzzz's Avatar
Myblackzzz
Default 2003 350z car won't start!!!!
I have a 350z with 117k miles. I have been dealing with this problem for over 6 months and the nissan dealership, my tuner shop, nor I can figure this out. So the problem is on warm starts sometimes it will start and other times it will not. Example: If I drive the 350z to 3 places 15 mins from each other and only stop for a few minutes at each place by the 3rd place I will have to let the car sit for an hour in order for it to start. IF I don't let it sit I can crank and crank; it tries to turn over but can't. It also has no problem making a cold morning start the next day. No engine check lights come on and no codes. Everything looks to be running in factory spec when viewed on a OBD scanner. I do have a aftermarket intake and inspected the MAF sensor and it looks to be clean.
Parts I have replaced in the last 6 months:
Crankshaft position sensor
Camshaft sensor bay 1 and 2
Starter
Positive and negative battery cables
Brand new Battery
New Spark plugs
New Coolant sensor
Hi flow cat converters (broke the stock ones)
Also have read articles like:
https://my350z.com/forum/maintenance...-randomly.html
Clutch switch sensor seems to be working fine too.
Thanks for all your help this has been really frustrating
Old May 31, 2015 | 07:40 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- it sounds like you've put a lot of research and effort into this. Also, a lot of parts replaced, which I assume are due to codes you've found? What codes have come up in the past? Also, are there any codes currently when your Z is in the NS condition?
Old May 31, 2015 | 07:53 AM
Myblackzzz's Avatar
Myblackzzz
In the past I had crank and camshaft sensors throw codes that is it. No codes show when car is unable to start. I bought this car used from a dealership so I don't know what maintenance has been done but car runs and drives great. No rough idle or anything weird.
Old May 31, 2015 | 09:37 AM
guitman32's Avatar
guitman32
There is a random computer/NATS issue that affects early models. It has been intermittent for me for the life of the vehicle (will go literally years with no issue, then all of a sudden wont start), and is cured by locking and unlocking via the key FOB (some say flipping the key works also). Best i can tell the problem seems to arise when im around other Nissans.
Old May 31, 2015 | 11:38 AM
Myblackzzz's Avatar
Myblackzzz
Mine problem is pretty consist if the car is driven for a hour it won't start. I did flip the key and lock and unlock the door. I was unable to get that to work. Is there a specific order?
Old May 31, 2015 | 05:01 PM
guitman32's Avatar
guitman32
Prob not the NATS/computer issue then. This is where knowing the vehicle history, any water damage, alarm/stereo work, etc is helpful to understand where to proceed with the diagnosis.
Also where a dealership/scan tool diagnosis might be your easiest bet to understand what is going on behind the scenes when you are trying to crank during the no-start condition.
Are you getting fuel, spark, compression, etc? A scan tool would be the quick way to verify all the old-school tests that you had to do to trace back an issue. For example, if you can verify you aren't getting spark during the no-start condition (but you are getting fuel and have good compression), then you work back through all the systems that would prevent you from getting a signal to your coil packs. Etc, etc, etc.
Sounds like it's not going to be easy to get the conditions right and be in the right location to perform the diagnosis, but unfortunately that is your only option.
JjL
East Canada
Jun 12, 2019 03:04 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
RyansZ33
Sep 15, 2015 05:54 AM
RWDBajan
Sep 8, 2015 06:25 AM
Darkspy
Sep 7, 2015 09:09 PM
