Valve springs - Cosworth VQ35DE with stock top end
Hey,
I have a recently built VQ35DE with the power goal of 600HP
Does anyone know where can I find more information about the stock spring rate?
I am using LINK ECU and concerned about valve float due to the use of ignition cut/hard cut rev limiter with that stock top.
I'd be fine with 7000 RPM as the limit if that changes anything.
Thanks,
- 2x Garret 2860RS
- Aiming at 17 PSI MAX
- Cosworth Forged Pistons (95.5mm)
- Cosworth Forged H Beam Connecting Rods
- New Nissan Forged Crankshaft (81.4mm) v
- Cosworth High performance Rod and Main Bearings
- Cosworth High Performance Main Bearing studs
Thanks,
