2004 350Z Cranks Too Long
Old Dec 28, 2021 | 02:17 PM
Lmerriman7's Avatar
Lmerriman7
Default 2004 350Z Cranks Too Long
So I’m having a weird issue with my 2004 350Z. When the cars been sitting overnight, it starts right up. If I shut it down and start it up, it starts fine as well no problem. HOWEVER, when I leave the car for up to 30 mins to a few hours it cranks for about 2-3 seconds before it’s finally starts up. Any idea what this could be? I’ve replaced spark plugs, coil packs and even the fuel pump with no resolve. Any advice would be greatly appreciated.
-Thanks
Old Dec 28, 2021 | 03:35 PM
JCat's Avatar
JCat
Try opening the gas cap before starting it (after 30 minutes or a few hours).
There might be a pressure or vacuum building up in your tank.
Old Dec 28, 2021 | 05:09 PM
Lmerriman7's Avatar
Lmerriman7
I tried unscrewing the gas cap and starting it and unfortunately it didn’t change the startup time.
Old Dec 28, 2021 | 08:32 PM
JCat's Avatar
JCat
Try pushing the gas peddle to the floor, releasing it, and then starting it. Any change ?
Also, try giving it gas while starting.
from google : https://mechanics.stackexchange.com/...10/27558#27558
Old Dec 29, 2021 | 04:14 AM
travlee's Avatar
travlee
Master
my guess would be camshaft sensors
Old Dec 29, 2021 | 07:40 AM
Lmerriman7's Avatar
Lmerriman7
I’ve tried fluttering the gas peddle when starting it but I’ll try putting my foot to the floor later this evening and seeing what happens.
Old Dec 29, 2021 | 07:45 AM
Lmerriman7's Avatar
Lmerriman7
I think your pretty close on it with that one. Now that I think about it, I had a Z that did the same thing in the past, although it was throwing codes for a camshaft sensor. This one isn’t throwing any codes but I’ll look into that too and keep ya posted.
Old Dec 29, 2021 | 07:49 AM
travlee's Avatar
travlee
Master
A friend of mine was having starting issues, never threw a code. When he replaces the sensors it ran flawless
Old Dec 29, 2021 | 07:55 AM
Lmerriman7's Avatar
Lmerriman7
I’ll give this a try then. Thank you so much! I’ll keep you all posted.
ItsFlashy
Aug 16, 2021 10:47 PM
AngelBunny6674
Jan 12, 2021 11:00 AM
Wsheff
Apr 17, 2017 02:08 PM
