Correct differential cover rtv procedure?
Old Dec 29, 2021 | 03:12 PM
Fricken Hamster's Avatar
Fricken Hamster
Default Correct differential cover rtv procedure?
When applying rtv, do I want to put it on the pumpkin side or the cover? The cover has grooves where the rtv is supposed to fill. I was going to put it on the pumpkin side, but does it matter? Also I was gonna place a bead, finger tighten. Wait an hour then tighten half turn. Then torque down the next day. Thanks
Old Dec 29, 2021 | 03:14 PM
Ponyryd's Avatar
Ponyryd
Either side should work, but I always do the cover, way easier to apply in a bench as opposed to the part in the car. When I do them I tighten fully and let it sit as long as possible before filling. I do this on everything
Old Dec 29, 2021 | 03:41 PM
Fricken Hamster
THanks for the response. Do you mean you just put the rtv on, then immediately torque to spec?
Old Dec 29, 2021 | 06:56 PM
Ponyryd's Avatar
Ponyryd
That’s what I do, yes. For the record I do not know what the actual procedure calls for, but this is what I always do, and always have done.
Old Dec 30, 2021 | 03:08 AM
Heel Til I Die's Avatar
Heel Til I Die
That's correct. You are supposed to apply the RTV to the cover as opposed to the differential assembly. Thread the bolts through and torque them down to 32 ft lbs of torque evenly. Applying to either side should work though.
POWUH
Wanted
Apr 6, 2011 09:54 AM
sir captian
Sep 19, 2009 11:53 AM
gocart
Cleaning & Detailing
Oct 16, 2007 09:48 AM
the bluez33
Nov 8, 2002 11:20 AM
