Are lightweight crank pulleys bad for you engine?
Are light weight pulleys bad for your N/A engine? I’ve been thinking about getting one because I plan on getting a tune soon and was wondering if it could help with at least +5hp. Asked one of my friends and he said the lightweight crank pulley could mess up the timing. Is this true?
https://www.evoxforums.com/threads/w...et-junk.50463/
It has failed in other cars. The 350z obviously is a different platform.
Its not "bad" but it is not good. You have to remember the crank pulley (Harmonic Balancer) was designed to help negate the internal vibrations you get from the V engine. With out the sufficient dampening those vibrations make it to the bearings shortening their life.
djtimodj
Sep 2, 2009 03:06 PM
