350z misfire or knock after changing plugs
Old Jul 8, 2022 | 02:41 AM
03350zred1's Avatar
03350zred1
Default 350z misfire or knock after changing plugs
Hi,
I have an issue. I recently bought this car. Changed the plugs since it has 96,000 miles on it. Car ran fine before changing plugs. I changed them with AutoLite double platinum APP5325. Now i have P0327 code. I've read the sub harness for the knock sensor is the culprit. Just seems weird how right after doing plugs this happens. Could maybe bad plugs cause this? I dont want to rip the intake apart for something that it might not be. Also, the car runs great but at idle there is a noticable shake and stutter every couple seconds. Appreciate any ideas
Thank you
Old Jul 8, 2022 | 04:46 AM
travlee's Avatar
travlee
Master
make sure you dont have coilpack wires 4 and 6 swapped... search on here, you will find what you need
Old Jul 8, 2022 | 08:30 AM
03350zred1's Avatar
03350zred1
I triple checked that. I have the correct way(solid gray wire for cylinder 4, and grey/red for cylinder 6)
Old Jul 8, 2022 | 10:38 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I'd never recommend anything but NGK plugs for the VQ. Too many reports of problems off-brand.
Old Jul 8, 2022 | 12:07 PM
03350zred1's Avatar
03350zred1
I think i will put NGK in. Im going to change the sub harness for the knock sensor. I scanned the car and still have a code for it(P0327). I read that the CEL wont come on for that code because its a "soft code", but it will derate it.
CDNFairladyZ
Apr 5, 2021 11:50 AM
vh5150
Apr 4, 2014 04:32 AM
Jurgen
Jul 6, 2013 05:39 PM
mestisoZ
Nov 13, 2008 12:22 PM
al v
Sep 23, 2007 08:18 AM
